Sounds like the extractor bearings may be seizing due to rust. This YouTube vide should help see if it’s the same thing and how to fix it! Good luck https://youtu.be/Iw6VXRSHyNM
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
I took it apart by removing the rubber spindle and three small screws. Then soak it in vinegar and rinse to remove food gunk. Lastly, re-lube with cooking oil (I used olive oil) by pouring onto back shaft and spinning the blades to suck in the oil. Reassemble. I still have to replace mine as the spindle is loose due to the bearings being worn out but at least it is useable again until then.
None of these people understand your question. The blade assembly is stuck in the blender base and will not untwist out of the base. The sport bottle untwists off the blade assembly leaving it in the blender base. I've tried using pliers on mine after taking it apart. Something is binding it from untwisting. What is the trick to untwist the blade assembly off the blender base?
Smart move. The blade assembly is almost frozen and the motor does not have enough torque.. You need to remove the blade assembly and completely clean out the bearing and reassemble after the Mr. clean operation. A lite dab of oil is also called for.
Hi, Disassemble the base from the jar, and check the placement of the gasket. Reassembly, with the jar upside down is gasket, blades, then base. While disassembled, rotate the blades by hand just to make sure that they aren't in a bind. Replace if defective.
