Is there a way to clean the iron? I don't know if that is the problem
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
SOURCE: MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
SOURCE: The iron will not produce steam.
There are several thermal sensors around the tank, did you make sure they were not damaged or bent...they are "bi-metallic" strips, meaning they are two disimilar pieces designed to have different thermal expansion rates so at certain temp they separate (open) or move together (close) telling the control logic board to enable heater. Do make sure you did not bend them or over torque them when reattaching to their respective attachment points.
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: [email protected]
SOURCE: Cleaning a Rowenta steam iron
According to the manual, you should use regular tap water as long as it is not above 12 grains of hardness. Never use 100% pure distilled water, Rowenta recommends using inexpensive bottled spring water.
SOURCE: My Rowenta Expert steam generation iron (seperate
Brown water and whitescale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
God bless you
