If you are doing the normal procedures and the water elimination function is working, you have power to the circuit board and controls. The circuit board wash cycle section is independent and aligned with the timer circuit, thus the Wash Cycle Controller has failed. All of the functions or options are one the one board and a replacement board needs to be purchased and installed.
Please confirm if the power was restored. Now If so then you can turn it off once again and wait for few minutes before switching it ON. Tap on sides while the machine if switched off to confirm if any coin was lodged while the power was off. If this is struck within you will need to remove the covers to clear the mechanism and reset the sensor action. Also check if there is power supply within the unit for the functioning of the control board.
It is possible that presence of moisture within the START button can trigger the cycle to continue as it keep the processor to continue the wash cycle,Hence you must remove the panel and board after disconnecting the wiring harness and use a hair dryer to warm off any presence of moisture on the panel and board. Do it with time to ensure there is no moisture within the panel. I think this must solve the issue. Repeat the work many times as sometimes moisture and dirt together might form a conductive bond to trigger as a pressed on switch. If possible open panel to clean switch pad.
Possible that the inlet flow is low , check the inlet valve and filter. Also try using the manual settings and if all the cycle works well then it is possible that the fault is with the controller unit or a possible errors from the level controller or the inlet valve. It is best to remove them , check reset after cleaning.
Hi, is this a new washing machine? If not, then these Maytag front loading washing machines use a paraffin locking switch in the front panel to lock the door
during operation. Now, if the switch has gone south and trip the the lock switch
without locking the door. Then the washing machine want turn on.
What is a parfin locking switch work is a small
container with paraffin (wax) in it with a heater. When the washing machine is
turn on. The control board indicate that the machine is in operation and a small
amount of current is applied to the paraffin switch to the heating element. This make
the parfin to expand trip the locking mechanism and locking door during
operation. Keep the door lock from accidental openings. It will take about 4
minute after the washing machine has quite it running operation to open the
front loader door. The paraffin needs to cool down to release the locking
mechanism. stewbison
The spin function is normally controlled by water level control switch not allowing operation until all water is pumped out,rinse should activate water valve to add clean water,if machine fills ok initially the problem seems to be in the controller not activating certain parts of the normal cycle.
Is your washing machine is manually operated or programmable type?
If programmable have it check by the technician or better yet bring it back where you bought it and use the warranty (for your new one)
If it is manually operated, see if the controls are wet, sometimes short circuit is the main cause of the unit not functioning correctly, have it dry the try to use it again
