Washing machine fills but won't start.
SOURCE: My Bosch Axxis WFL pump drain blocked. I had a
Hi there, i have prepared two links. The first one is the original manual you requested and the second link refers to the quick reference guide.
Click here for the first link to your original manual.
Click here for the quick reference guide.
SOURCE: Bosch WFL 1660 Front end
After disconnecting the mains open up behind, it could be a shock absorber (damper) which is broken.
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites for spares.
SOURCE: bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
SOURCE: Washing machine heater not working
Only way to be sure if it is the heater, is to test it with a meter.
They are a fairly straightforward job to replace
Please rate my solution.
Thanks..
SOURCE: bosch washing machine not emptying
There should be a filter located at bottom right front of washer.
To clean it ,unscrew anti-clockwise, remove and clean it.
If you cannot see the filter, it may be behind a removeable plastic cover at bottom of washer..
Hope this helps you
