SOURCE: Does old mother board supports LCD monitor?
You’ll be fine.
Most LCD monitors either have VGA connection you’ll need or have VGA plus other connections but, all you need is the VGA connection.
SOURCE: I have asus Vh192d and
Anytime you have straight lines on an LCD monitor, it indicates damage/failure in the LCD panel itself. The only fix is to replace the LCD panel.
SOURCE: IN MY ASUS LCD WHICH
See my tip here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
SOURCE: where to find new power supply board (EADP-86AF B) for ASUS PG221 monitor
Instead of replacing the whole board, look for bulging (top) or leaking (bottom) electrolytic capacitors. Usually the failure is one or more of these inexpensive components which you can order from Digi-key.com and have delivered next day.
Try to stick to the correct value (uF) but you can go over voltage. do NOT go under voltage. for instance you can replace a 1000uF 16V cap with a 1000uF 50V cap, but not with a 10V.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
