I would recommend a Mid-Grade gas and if it stored in anything bigger then 2 gal. then some Sta-bul should be added to to the gas can.
It should use regular fuel unless the fuel cap say's Mixed fuel only Or has a pic of a gas pump + an oil drop. The cap on the Left in this picture, Is for mixed fuel = 2 stroke the cap on the right is gasoline only. You may have to zoom in to see the detail of + oil drop
SOURCE: I have a toro lawnmower moel 20695 and whem i
check the gas line between the carb and bulb. Or it could be the plastic primer bulb itself. -a small tear or slice could easily go unnoticed.
SOURCE: does toro lawnmower need oil/gas
It depends, Toro made 2 cycle and 4 cycle Mowers......Look and see if there is a oil dipstick,If so it is a 4cycle , If no dipstick or plug at crankcase to check oil then it's a 2 cycle
SOURCE: tire on toro lawnmower has de flated how do i re
the valve is on the inside. sometimes you can clean around the inside of the rim. to remove an dirt. also if it has set for long periods it may be dry rotted.. becomes very cracked on the outside of the tire wall.
