Kenmore Elite 45986 Front Load Washer Logo
A
Anonymous Posted on Jun 25, 2014
Replace washer spin basket kenmore elite 110
I fear that my washer spin basket has fallen off its track as it were. It rotates, but not properly. Is it supposed to fit in a track or something to ensure proper spinning? I hear a rubbing and a noticeable clunking about twice a revolution when I rotate it by hand.
Steven Brandon
Level 3:
Master:
  • Kenmore Master 462 Answers
  • Posted on Jun 26, 2014
Steven Brandon
Kenmore Master
Level 3:
Master:
Answers
462
Questions
0
Helped
117681
Points
1705
Sounds like a bad bearing on the rear of the tub. If you remove the rear access panel you will see a large pulley and belt. That attaches to the inner drum (basket) and spins it. It floats on a bearing just behind the pulley. If the bearing is bad then you will be able to move it up and down about .25 to.50 of an inch.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
5 Related Answers
onthejob5130
onthethejob1
  • 640 Answers
  • Posted on Dec 26, 2008
SOURCE: kenmore elite he3 model # 11044832200 gives me a f15 error code.
it because you change cycles in the wash mode,,over reset...all fixes accept reset unplug .needs technician...if you fell you can do this repost question,,as replacing motor control unit
onthejob5130
onthethejob1
  • 640 Answers
  • Posted on Dec 27, 2008
SOURCE: Kenmore 90 Series trouble with spin cycle
belt needs changing
Anonymous
  • 1937 Answers
  • Posted on Oct 15, 2009
SOURCE: Kenmore Elite washer wont spin
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.20932992
See the section on the motor and transmission.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft.
Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning. This may be the baseball in spokes sound (the plastic prongs clicking together.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Anonymous
  • 15935 Answers
  • Posted on Sep 14, 2010
SOURCE: Kenmore Elite 110 does not spin/agitate/drain
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
The new outer tub with bearing W10128830 cost approximately $197 dollars.
If you can get access to the shaft it may be an Emory cloth will help smooth things down so that you no longer get the OL code.
This is an ambitious do-it-yourself project... as most appliance repairmen don't understand how this machine operates.
http://media.fotki.com/1_p,srrtbrrfbdbqgkkxgtqsskgwtqkq,vi/bqkfstqqfxrqqbkwgqdxbwsqrwrtq/1/1303472/5961857/image828956817962821589img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Anonymous
  • 15935 Answers
  • Posted on Sep 16, 2010
SOURCE: My HE3T Elite Washer knocks
file:///C:/Documents%20and%20Settings/Ryan/Desktop/Appliance%20Repair0/Dishwashers/
I get F51 error on my Kenmore Elite Oasis washer. During the spin cycles, it makes a loud, grinding noise. It appears that some of the plastic over the tub has been sheared. What do you recommend? ...
First, what is your model number?!
The F-51 error code on this washer indicates that the machine control board in the console detects a motor RPS (Rotor Position Sensor -- tachometer) failure. This can be caused by a number of different problems. You could have a bad RPS sensor, a failed motor, a wire harness connection problem or an item stuck between the spin basket and the outer tub that is interfering with spin basket rotation. A water filling problem could also cause this code to be displayed since the basket would have excessive friction if water is not entering the machine properly. With the washer off, spin the basket to see if it rotates freely. If you detect resistance or suspect that an item is stuck between the basket and the outer tub, you will likely need to remove the basket and check this area. Remove the basket and check for foreign objects or debris.
If the basket spins freely, make sure that your water supply cut-off valves are fully open. Shut off the water supply and remove the hoses from the connections on the back of the washer. Place the ends of the hoses in a bucket and briefly turn on the water supply to check the flow and water pressure coming from the end of the hoses. Check the inlet water valve screens for deposits or debris that could interfere with the water fill. The motor will begin to spin the basket before the washer completes the filling function. If the filling is slow, it could cause the F-51 code.
If the water supply is okay, you could have a wire harness connection problem, failed RPS sensor or a number of other failures. Unplug the washer to disconnect electrical power before accessing internal components. Internal metal edges in the washer can be sharp. Protective gloves are recommended.
I recommend that you unplug the washer and access the control board first. Check the wire harness connections on the P10 and P5 plugs first. Measure the resistance through the motor and the RPS sensor as shown below. This may point you in the direction of your failure. If you need more help, submit additional details.
I have a Kenmore Elite top loading washing machine that gives me the error code F51 incessantly. Any idea what this means?
10helpful
What does the error code F51 mean on the kenmore elite oasis he?
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Leaking and F51 error code on my Kemore Elite Oasis Washer
7helpful
What does it mean for a code when my Kenmore elite washing machine is flashing F 51
1helpful
Our Kenmore washer was flasing F 51... What does that mean. We have the Kenore elite Oasis
My kenmore elite oasis HE is not working and the code f51 shows up. What is this code?
6helpful
Kenmore elite toploader code f51
2helpful
Kenmore elite oasis model 27082605 type 580 has f51 code what can i do
Was getting the f 51 code, now d 5 code. its a kenmore elite oasis canyon top load washer.
Alexander
vince
