SOURCE: how to clean ice maker door on a Kenmore
is it a side by side or trio with french doors ? we will asume is a side by side under the dispencer trip there are two small slots were you insert a flat screw driver. now twist to unlock them once you remove that cover you can see more inside and how you can have more access but be care ful disconect unit if possible
SOURCE: ICE MAKER NOT WORKING
whats the freezer temperature? it has to be at last 17.5 degrees for the ice maker to work properly.
SOURCE: adjusta cube ice maker spilling water
check at the back of refrigerator were water line comes in see if there have eany hole or check your freezer may be it (ajar)
SOURCE: Ice maker drip into ice bucket and manual cycle leaks more water
Need to take the ice maker out to measure the amount of water input into the ice tray. In this case the tray was already full (from the leaking valve). The spillage I saw was just the tray overflowing. Time for a new valve.
SOURCE: Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
