The only ways around blocked sites are to either turn off the protection on your computer (a BAD thing to do) OR If its on a network ask the person who set it up to allow the site in question. OR If you are trying to get to a site via another persons internet connection that is NOT your then you should consider getting your own internet service. You didnt give enough information to enable me to say any more than that. eg. router, modem, network, site address etc etc etc.
SOURCE: cannot connect to admin on GT704WG
the defaul user: admin and the password: password, this is when you have reset it to the factory reset botton on the back. The ip address is 192.168.1.1
SOURCE: Linksys Wireless-G 2.4Ghz Broadband Router Problem
This is a common problem with linkys wireless g routers, as you say that you modem works fine with usb..no problem with your isp, so go head and first upgrade the routers latest firmware..reset and reconfig your roter your issue will get fixed..try it out.
SOURCE: Netopia DSL Router (DHCP Server) was giving address to connect to Internet
If this is a DSL Gateway Router, check the settings on the modem and make sure that the DHCP server is enabled.
it woould be of great help if you could provide the exact model number of the Netopia modem so that I could check if there is configuration page which you can access and check the settings..
regards,
SOURCE: Have a new Hughes net HN9000 satellite service and
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
SOURCE: belkin g wireless modem router f5d7634 always disconnect
try to reduce the MTU settings on your router.
If possible upgrade the firmware of the router.
Click here for more info about the networking
