I have just connected a smeg S650s which is new and has been stored. When I turn it on the water temp,etc and normal programme and spin come up. It doesnt seem to move on from the wash cycle to the spin. I can do it manually but then the spin cycle doesnt seem to stop. Goes on for so long so have to stop it manually.
SOURCE: Machine stops in Rinse & Spin Cycle & leaks water
suspect problem is that water is not draining fast enough so when machine gets to spin there is too much water present which gets thrown up thro thew soap drawer. check the filter. on many hotpoint filter is not obvious. at back, take off bottom panel. you will see a large dia hose going from bottom of machine to pump. undo this hose at the tub end and the filter is inside it. be carefull. if you havn\'t managed to drain, a lot of water will come out. if this doesn\'t work, get back to me if you want
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
SOURCE: washing machine spins but doesnt drain water until I turn it back to spin only
timer contacts are burnt replace the timer
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
