Why can't I send a fax from my Panasonic KX-FL511 fax machine?
SOURCE: KX-FL511 Panasonic Fax machine will not receive document
Try going through menu and turn ECM to no or invalid also try adsl filter on incoming line
SOURCE: Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
SOURCE: need user manual
You can download a manual here:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Fax/Copier/model.KX-FL511
SOURCE: I have an hp kx-fl511 fax machine. Has new toner
Hi!
Try to reset advanced features to their default settings
RESET=NO [±]
To reset the advanced features:
1. Press {MENU}.
2. Press {#}, then {8}{0}.
3. Press {A} or {B} repeatedly to select “YES”.
4. Press {SET}.
5. Press {SET} again.
6. Press {MENU}.
Thanks
Rylee
SOURCE: Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
