Bottom freezer, a lot of loud noises, makes a lake of ice in the bottom tray.
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out. IT costs $200/yr. They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit. He said that a new motherboard and the labor alone was going to make it $498. Anyway, he had ordered a new motherboard. Apparently the motherboard wasn't working. It is located in the back bottom left side of the refrigerator behind the panel. There is a compartment on the lefthand side that slides out and houses the motherboard. He put that in and also had to fix the fan that is in the back of the freezer. That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all. So at least take a look at the fan in the freezer. Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover. Maybe that's the problem with your refrigerator, the fan. Hope that's all it is. Good luck!
SOURCE: Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
SOURCE: Kenmore Elite Bottom Freezer Refrigerator
This first thing I would do is remove the panel on the back of the fridge to access the control board. It should be about half way up on the left hand side if you are looking at the back of the fridge. There should be four 1/4" screws to remove. In the middle of that board there should be a reset button. Press that button then let me know if that worked.
SOURCE: Kenmore bottom freezer refrigerate leaks
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Testimonial: "Greatly appreciate yor help, Mike. Found screws to remove back panel, but the ice maker is plugged into a hole in panel can this be unplugged?"
SOURCE: Control Pad displays Er CO.
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
