Maytag Neptune FAV6800AW Top Load Washer Logo
A
Anonymous Posted on Jun 21, 2014
Where d0 i get the repair manual for maytag neptune tl
5 Related Answers
Anonymous
  • Posted on May 12, 2008
SOURCE: Maytag Neptune TL
Lr stands for motor not running properly.  Solution says to call for service.
Anonymous
  • 96 Answers
  • Posted on Jun 08, 2008
SOURCE: maytag neptune tl
Code OP means lid is open. If it really isn't, then the problem is with the switch that sense whether the lid is shut or not. Could be bad switch or bad connection.
sagacious
GORDON'S APPLIANCE SERVICE
  • 283 Answers
  • Posted on Oct 02, 2008
SOURCE: Maytag Neptune TL FAV6800AWW Overflows
Check the pump, pressure switch and related hose for small obsctructions. For reasons unknown they moved the pressure switch location to above the pump. d60f89f.jpg
Anonymous
  • 335 Answers
  • Posted on Dec 15, 2008
SOURCE: code dc appears and has trouble draining and spinning during last 12minutes
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives the spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Anonymous
  • 335 Answers
SOURCE: I need an instruction manual for Maytag topload washer Neptune TL
Get the Service Manual this will help you diagnose issues with this washer.  I found a Service repair manual on this site search for this; FAV6800 Manual.  Check the postings and you will find a URL to the manual.
From another member a step by step to dump water from machine in diag mode  ""One other thing I learned for those of you who don’t want to bail out the water in the tub. If you want to have the machine drain the excess water without bailing this should work. Turn the machine off and make sure the "locked door" light goes off. Then hold the "Spin" and "Enviro Plus" buttons at the same time for 3 seconds. "00" should then show up on the display. Then hit the "Delicate" button, then the “Pre-soak” button. This should activate the pump and get all the water out. Once the water is out hit the off button. You then may want to try the Spin cycle alone. These directions can be found on the Troubleshooting Manual found folded up behind the rear panel of the machine where the main electrical circuit board is located.""
2helpful
Need to reset the program of our maytage neptune TL ver: FAV6800AWQ
""need to reset the program of our maytage neptune TL ver: FAV6800AWQ ""
The only hard reset to the Control Board is to unplug your FAV6800A from the 120VAC service outlet then reconnect.
I feel this will not clear your machine issue. What do you mean by reset the program of our maytage neptune TL?
Fav6800aww machine wont stay balanced move the clothes around it starts back up for about one minute then stops code comes up dc thanks earl
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
In that Sticky I discuss what is the cause of DC or UC unbalance errors and the fix.
I have a Maytag Neptune TL ( Model # FAV6800AWW) washing machine does spend but clothes still soak after it done. when you spend it by hand, it only spend in counterclockwise.
Any error codes. What happens if you start a Spin Only Cycle witht the same load? Does the times stay stuck at xx minutes in the LED display and the machine constantely starts and stops?
The more info on your problem the better.
Do you want to DIY the fix? Google this; Neptune TL Washer FAV6800AWW see the 5th post down here for general info and the Service Manual. If you want to try to DIY the repair I will help.
I keep getting error code dc and it wont spin
Somewhere on this forum I have a response to DC or UC unbalance errors and the fix. It's hard to find my past post on this forum.
This is a DIY Appliance repair forum and you can get the Service Manual and repair support posted in the sticky at that site.
4helpful
Constantly stops with code "DC" even with very
Google this Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum no cost and you can get the Service Manual from this site.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues with the machine. At that post I discuss what cause is and the fix.
In that Sticky are other what I find to be common Service Repair notes for issues with the machine.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air f
I have a Maytag Neptune TL washing machine, it runs almost all the way through they cycle but on the last spin cycle it stops and the digital display shows LO. Can you help me?
LO error code:
Locked: Lid has failed to unlock -
the machine has repeatedly tried to
unlock the lid. Push lid closed to
make sure nothing from the inside is
pressing against the lid, preventing
unlocking.
Is that the issue? Have the Lid locks failed to release and you can't open the Lid?
Or have the Lid Locks released so you can open the washer lid but the error code LO remains?
If you want to DIY I will help you.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help. No cost to you for the support..........D*ick
My MAytag will not spin the water outta my clothes on spin cycle
If you machine is a FAV6800A or FAV9800A don't worry about the last two letters of the model number.
Maytag washer Neptune TL error message: dc stops during spin cycle; leaves water in tub
See my post Clutch Fix but I recommend you go to real DIY forum.
I can't find most of my repair post in this forum. This forum to me is a "Call In a repair tech forum" for this model and that is OK if you can't do basic DIY repairs.
I don't want to put in a direct link to the washer repair forum of my choice so put in your browser this phrase;
Appliance Repair Forums > Appliance Repair Talk > Washers > Maytag/Magic Chef/Admiral/Jenn-Air
This is a true DIY Appliance repair forum.
If you need help open a post in that repair forum and I will try help you through your issue.
0. We need a manual for Maytag Neptune TL. IT IS
f your machine is a FAV6800A or FAV9800A see if this post will help. Service manual link or located there. here it is just in case
Clutch Fix
Here it is just in case;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
3answers
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
