Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
E3 warning light Bosch Maxx Classic
I have a regular E3 warning light between loads or cycles. Booklet suggests that door is not closed properly. This is not the case! A temporary solution which sometimes works is to turn the machine off for a few minutes then back on again and select a program. This works about half the time but causes lengthly delays in completing the day's washing. Machine is under warranty but hope to solve this problem today. - Barry Sanderson
6ya staff
SOURCE:
Anonymous
  • 1185 Answers
SOURCE: Missing instructions Bosch MAXX 4 Comfort
Click on the link below ,fill in the details re the model number and it will be available as a .pdf
http://www.boschappliances.com.au/content.asp?document_id=192
If you have not got Adobe Reader go to www.filehippo.com and get a copy there
Posted on Jul 28, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: no power to my bosch maxx classic
Hi, check the following trouble spots below. you will find the issue in one or, all the areas stated.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch/door switch
The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
**If you are getting power to the washer and, step 1 and 2 check out ok, replace the timer control or control Board and start switch as well.(You can test the continuity or, resistance level of the Lid switch/door switch with a multimeter(ohm).
Posted on Aug 17, 2009
Jarrod Matthews
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
Anonymous
SOURCE: I have E3 error code on a Bosch washing machine
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Posted on Nov 22, 2009
Sanja Salatic
SOURCE: What does error code E2 mean? I have a Bosch Maxx
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
to fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
Posted on Nov 25, 2009
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
Kenmore elite washer will not start
The problem might be that the black pin (about 3/8" long and 1/8" in diameter), that normally sticks out of the frame of the washer at about the 2 o'clock position, and which is pushed in when the door closes, has broken off. If this pin breaks off, the washer will not recognize that the door has been closed. In my opinion, the pin is most likely to break when you close the door and the door was not properly aligned with the door frame -- in which case the pin will be sheared off. Let me know what you find.
Jun 29, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Dryer not working. Lights reads PF
If your dryer is showing code PF, then a power failure interrupted the previous load from completing and you will need to restart the cycle. You will need to press and hold the "Start" button to restart. If the error message reads E1, E2 or E3, then there is a more serious problem and a technician will need called to resolve the problem.
Kenmore dryers come equipped with door switches. If the door is not closed entirely, the dryer will not start its cycle. If the other indicators seem in working order and the door is properly shut, the door switch may be faulty. On some models of Kenmore dryers, there is a warning light to indicate if the door is open. If the "Door Open" light is still lit when you have closed it and heard it click, you should look into replacing the door switch.
Another possibility is the thermal fuse. This fuse is usually found in the back panel near the exhaust duct. If the dryer overheats, the thermal fuse will blow, shutting down operation of the dryer until the fuse is replaced.
Check the wiring from the outlet. If you have recently had to convert from a four-prong wire to a three-prong wire, or vice versa, the connections to the dryer may be faulty. Make sure that the red and black wires are connected to the proper hot terminals, the green wire to a ground and, if present, a white wire to the neutral connection.
Thanks and have a nice day.
Jul 04, 2011 | Kenmore Elite HE4 Electric Dryer
My kenmore front load washer has aquired this rank moldy smell. If don't take the washed load out immediately the nasty smell penetrates into the clothes and smells even after drying. Is there some sort of...
you can run a regular cycle with bleach as instructed in the manual. there may be mold on the rubber where the door closes. wash this with water and bleach. to avoid this problem in the future you can loosen the light bulb then you can leave the door open a little all the time with no light. press the off button when not in use.
Jul 26, 2017 | Kenmore 44921 Front Load Washer
I have E3 error code on a Bosch washing machine maxx classic - what does it mean? thx!
Jun 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Frontload washer will not complete a load..shows E3 on display
e3 is a motor sensor not reading the motor properly un plug the unit for 5min and try it that will clear it but you may need a new sensor check the connectors at the motor sensor
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Bosch washer error code e3 what does it mean?
Error "E3" on a Bosch front loader means there is a problem with the door. Either it is not closed properly (user error or a blockage) or the locking mechanism has a fault. Check to see that there is no object shoved in the latch hole (our 2yo just did that) preventing the door from closing properly. If it is not that, a technician is advised. I tried to get into the machine to fix out issue but could not get to where the issue is.
Aug 02, 2008 | Bosch Washing Machines
MALBER WD 1000 - UNSPUN HERO
use the rinse cycle on the machine in conjunction with the spin that should solve the problem
Apr 16, 2008 | Malber WD1000 Front Load Washer/Dryer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
1,500 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
