SOURCE: placement of water in the roaster
Hi Joan,
To prepare a turkey, I first spray the liner and grate with Pam. Then prepare your turkey as usual. I do not salt the turkey as I found out the hard way that it make the juices too salty. Instead, I stuff, then butter the outside of my turkey. You should have the liner inside the roaster, with the grate on top. Put your turkey on the grate, add a can of chicken broth. Cook per instructions. I have found out that the tukey will be done quicker then it states in the instructions. If this happens, just keep the turkey warm in the roaster. Good luck.
SOURCE: do you need to put water between pans in electric
yes you need water to make it steam heat so your dishes do not burn
SOURCE: Should I put water between the pan and the roaster
how do you bake a cake in the Nesco oven?
SOURCE: I'm trying to keep a large amt. of food warm in my
Turn the roaster on high for 30 minutes till the water is very hot then place the setting to warm. It will stay very hot to serve this way for hours
SOURCE: do you put water between the pan and the roaster?
My wife and I add fluids based on the food being cooked. A roast might get a little wine or other spirits added for flavoring. Same for poultry. The addition of fluids needs to be adjusted for what your placing in the pot, some veggies (especially frozen) will add moisture to the pan. The initial amount of liquid in the pan should be about a cup to help prevent the meat from sticking to the pan and to facilitate gravy.
As the heat is mainly applied to the sides of the device bottom burning should not be a problem. We have made stews, soups, and roasted meats for our main dishes in our cooker. I hope you have plenty of hearty meals with your cooker.
