Homelite Mighty Lite Lawn Trimmer  Logo
A
Anonymous Posted on Jun 21, 2014
Is the fuel line filter necessary for trimmer to work
I had to remove the fuel line filter in my mc collough strimmer because it was completly blocked. can i use it for now till i get a new filter
roeb
Level 3:
  • Homelite Master 819 Answers
  • Posted on Feb 06, 2019
roeb
Homelite Master
Level 3:
Answers
819
Questions
0
Helped
385215
Points
2343
Reverse blow carb. Cleaner through the filter blow in same direction with compressed air and should be good for many more years that is if you clean tank completely with carb. Cleaner and compressed air and check all fuel sources. If fuel is a bit dirty place paper napkin or rag in funnel and use as filter when adding fuel.
4 Related Answers
Anonymous
  • 53 Answers
  • Posted on May 11, 2010
SOURCE: i have a homelite ut20585 string trimmer that i
Ok you have to be 100% certain that you reassembled those hoses correctly, if any one of them is incorrect you are dead in the water as far as getting fuel properly. Tell me 2 things, Why did you feel they needed to be changed? and now that you've done it does the new primer bulb pump fuel at all, and maintain a full bulb of fuel after 15 min?
Anonymous
  • 3 Answers
  • Posted on Sep 08, 2010
SOURCE: Trimmers: Homelite Easy Reach-25cc-Model #
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
John Wilson
  • 37 Answers
  • Posted on Jun 15, 2011
SOURCE: Homelite string trimmer 275, which fuel line do
its the line to the carb You have to find the one in the fuel tank Its more than likely the longest one If it hasnt been removed it will have the old filter attached to it already. if not it will be the longest one
Anonymous
  • Posted on Jul 18, 2012
SOURCE: What is the gas/oil mix for fuel for my homelite mighty lite 26vt gas trimmer?
50 to 1
2answers
Strimmer line breaks after a few yards use
buy better line. and chain link fences are ******* lines
Apr 28, 2019 • Garden
Which fuel line goes where on Colibri Partner strimmer
the carby to tank
use the primer button to check lines are correct
once you get fuel in the primer
Flymo Partner Colibri SST250
trial and error
the longest hose
in tank filter line through the tank grommet to carby
short single hose
the other outlet goes from the carby back through the grommet into the upper part of the tank
Sep 08, 2016 • Garden
1helpful
How to load new cutting line onto a McCulloch Strimmer TM250
You can probably find a Youtube demonstration video.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
52cc land master petrol strimmer. Will only throttle with choke on full. With choke fully on it works at full power, without it cuts out. Please help. dave
Obviously fuel starvation, start by replacing the fuel filter in the fuel tank on the end of the fuel hose, check the fuel lines from the tank up to the carb for signs of leaks, cracks or damage, replace if required, there is a filter in the carb itself, so the next thing is to remove and clean the carb.
Aug 19, 2013 • Garden
Husqvarna 326 ls e-tech trimmer
Yes the 326LS is an e-tech strimmer, Fuel to oil mix ratio is 50:1
50 parts fuel to 1 part oil.
I have a TB70SS trimmer. I used my trimmer on half my yard with no problem, turned it off to cut the grass with the lawnmower, then tried to turn on my weedeater again, and noticed the primer bulb would...
First, the primer/purge bulb does NOT have to fill completely to function. It's purpose is to remove old fue and AIR from the fuel system (carb) and move it back into the fuel tank. You normally will have an air pocket in the bulb. An air leak in the fuel system or loose carburetor screws or fuel lines in the wrong location can cause your problem. Check the fuel line and fuel filter for a good connection in the fuel tank. Remove the fuel pump cover on the carb and make sure the very small, round, wire mesh filter is not clogged with debris. When old fuel lines deteriorate, they crumble and if the filter is broken off, the fuel line to the carb will ingest bits and pieces of old fuel line. Check all these things and post back.Sometimes, if the bulb is on the carb, a check valve in the carb can stick. When you check the condition of the mesh filter inside the carb (opposite the side with the vent hole), then liberally spray with WD 40. Strong solvents and cleaners can SWELL up the tiny check valves in the carb, causing problems. So you see, it is hard to pinpoint exactly what happened without some removal of parts and diagnosis.
2helpful
Gas line for weed wacker which line goes to filter larger or smaller?
The smaller of the (2) lines will go to the in-tank fuel filter/weight. Depending on the model, the line will attach to the filter with about 2.5-3.0 inches of additional fuel line within the fuel tank.
The larger fuel line is the return line and needs to go into the fuel tank about 1/4 inch or so.
You should have both size holes at the bottom of the fuel tank to accommodate. Insure you are using the correct fuel line as a complete seal is necessary due to slight pressurization and to prevent leakage.
Mc culloch tm 250 strimmer. petrol/oil ratio
40 parts fuel to 1 part 2/stroke oil
Aug 05, 2010 • Garden
Cracked fuel line
you can get many sizes of hose at the home depot
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
