HP Pavilion dv9000z Notebook Logo
A
Anonymous Posted on Jun 19, 2014
Command prompt a system restore in a hp pavillion note book
Alexandru Adamovici
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Apr 13, 2017
Alexandru Adamovici
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
800
Points
15
If you still have the recovery partition:
Restart your computer then look for the F key which controls your BIOS then look for the option "reload default setting" then follow the on-screen instructions.
If not, please let me know what version of windows you have installed, the type of recovery media?
5 Related Answers
Anonymous
  • 188 Answers
  • Posted on Dec 21, 2007
SOURCE: HP Pavillion dv 5000
I would test the hard drive - The easiest way to test it is to download the hitachi drive test - It comes as a CD image file which you can make into a bootable CD. You will need a program that can burn image (ISO) files to CD - if you dont have one use CD Burner XP which is free at www.cdburnerxp.se
Run the advanced diagnostics and it will do a thorough scan of the drive.
I would lay odds the drive is failing. If data is important to you i would recommend trying to backup data before doing any more testing.
Don
Anonymous
  • 131 Answers
  • Posted on Apr 30, 2008
SOURCE: hp pavillion trying to boot from dos mode
my pc is writting Disk boot failure, insert seystem disk and press enter. pls help.
Richard Stone
  • 39 Answers
  • Posted on Apr 24, 2009
SOURCE: I have a thin blacl=k line across the screen of my
Unlikely but possible that the video card has gone bad. the easiest way to check is to hook it up to an external monitor (if it has that capability) if the line is on the external monitor then it is the video card and depending on the model of the laptop it may not be able to be repaired. video cards are often built in and cannot be exchanged.
There are 3 things normally cause this. the first and cheapest of the 3 is to check the video cable. normally you wont have to take more than the keyboard and the faceplate between the keyboard and the monitor off. once those are removed you should see a flat ribbon cable running from the monitor into the laptop. make sure it is plugged in good. if it is then it is passable that the cable is bad. you will need to order a replacement cable either from ebay.com or you may be able to order from hp.com. it is a little of a pain to take the screen apart and get to the other end of the cable but it can be done. just remember to be gentle and don't pull to hard it is plastic. if you pull gently and nothing happens chances are you missed a screw somewhere. the other thing that normally causes this is the monitor going bad. a replacement monitor can usually be found cheap on ebay.com just make sure to get one with warranty.
Anonymous
  • 79 Answers
  • Posted on May 03, 2009
SOURCE: i want to wipe the hard drive clean and then use
In case you have lost the supplemental cd, here's a helpful resource. You can use this software to backup your existing drivers and restore later. http://small.drivermax.com/soft/dmx/drivermax.exe available at http://www.innovative-sol.com/drivermax/
Anonymous
  • 169 Answers
  • Posted on Jul 03, 2011
SOURCE: hp netbook 110-97TU 1: Text box
having this issue may cause by hardware problem or key board malfunction, if the computer is still under warranty call your manufacturer and have it replaced.
What is the command prompt in the HP Pavilion a6037c Vista recovery partition that allow me to type the command to recover to the factory settings.
You can access the HP Recovery Manager software using the "F11" command during the boot-up process. The Recovery Manager is a preinstalled utility that can help you resolve issues on your computer system that affect its proper function, such as viruses, system errors or hardware corruption. Restore your computer only as a last resort, since all the files stored on the hard drive will be lost during the process. The restore process can also be helpful in wiping the computer clean before passing it along to another user.
Restart the computer. Press the "F11" key when the "BIOS" messages appear during the start-up process to open the "HP Recovery Manager." This step must be completed before Windows has a chance to load. Click "System Recovery" and click the "Next" button. Click "No" in the Microsoft Restore window that appears and click "Next." Click "Next" in the "System Recovery" window to initiate the restore process. The hard drives will be reformatted and the computer's software returned to the factory settings. Click "Finish" to restart the computer with the original operating condition in place.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=18703&docname=c01895783 - RecoverOS
tip
How to run System Restore from the Command Prompt?
Here's how:
  1. Restart your computer to boot your system in to Safe Mode.
  2. Go to Start>> Turn off computer>> Restart.
  3. When the message "Please select the operating system to start" appears, press F8.
  4. Using the arrow keys, highlight the option "Safe Mode with Command Prompt" , then press <Enter>.
    Note: If your system is a dual-boot or multi-boot system, choose the appropriate installation using the arrow keys, then press Enter.
  5. Be sure to log on to the computer with the account that has administration privileges.
  6. Enter the following in to the command prompt: %systemroot%\system32\restore\rstrui.exe
  7. Press <Enter> on your keyboard.
  8. Follow the onscreen instructions to restore your computer to an earlier state
on Jul 05, 2010 • Computers & Internet
My HP Pavillion dv7 3112sa won't boot and remains
Hi, at startup try pressing f8, this should give you a menu, select 'start windows with last good configuration', this should restore windows to the state before it started rebooting randomly. Failing that...try starting in 'safemode with command prompt' and then do a 'system restore'- press f8 again at start up and then follow the instructions below. this should restore your system to a previous state when the computer wasn't doing random things.
  1. Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  2. Use the arrow keys to select the Safe mode with a Command prompt option.
  3. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  4. Log on as an administrator or with an account that has administrator credentials.
  5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  6. Follow the instructions that appear on the screen to restore your computer to a functional state.
I hope that this helps you to sort out the problem. Toni
1helpful
Hp pavillion 560w computer factory system restore feature does not work i can launch the system restore feature and it starts ok and asks me to confirm this action so i say yes and then on the next...
hELLO THERE
thank you for choosing fixya
ok here is the best way to hopefully take care of this that i have used on several older hp pavillions
when you go thru the recover system and you get to the black box and it says no device found or something similar at the command prompt type list and then press enter and it will give you a list of the 2 drives like c: /hp-recovery fat 32 and d: / hp_pavillion when it does this exit and type in the recovery drive with colons like this d: then type cd\windows\system32 then press enter then at the command prompt type rd /s catroot2 then press enter and answer y to the next screen then type exit and then once it has exited now shut down the computer if it does not do this for you
now upon restart it should recover your system automatically with no problems ok
please feel free to rate this solution
best regards mike
1helpful
2answers
When I log into my computer it says "loading personal settings" then immediatly logs back off? what do I need to do to fix it without reformatting
Try to boot your windows to SAFE MODE use the steps below:
How to start System Restore by using the Command prompt loadTOCNode(2, 'moreinformation'); Note You must be logged on to Windows with a user account that is a computer administrator to complete these steps. To verify that you are logged on to Windows with a user account that is a computer administrator, visit the following Microsoft Web site: http://support.microsoft.com/gp/admin (http://support.microsoft.com/gp/admin) If a new program has made your computer behave unpredictably, and uninstalling the new program did not help, you can try the Windows XP System Restore tool.
Important If you have not previously set a restore point in System Restore, you cannot restore your computer to a previous state. If you are not sure, or if you have not previously set a restore point, contact Support.
To start System Restore using the Command prompt, follow these steps:
NOTE: IF THE PROBLEM STILL PERSIST AFTER SYSTEM RESTORE OR YOU HAVE NO RESTORE POINTS AVAILABLE. YOU MIGHT NEED TO REFORMAT YOUR PC.
Thanks.Cheers!
2helpful
Hp pavillion dv6000 I need to do a system recovery. How ?
  • Hi, these are instruction to perform the System Restore; follow them carefully! You will need Disks (CD or DVD); only if you needed to Backup System Files, before restoring the system; in which you may be (prompt) to do so. So have available beforehand, at least 7ea, of (DVD-R), or (DVD+R), or (DVD+RW) @ 4.7 GB ready! *Note: It is important to make, Recovery Disks for the computer as well, in the event of system failure! *System Restore: 1. Go, to: Control Panel 2. Click, on: System and Maintenance 3. Click, on: Backup and Restore Center 4. In the (left) Tasks area, click on Repair Windows using System Restore 5. Windows may take up to 5Mins, to Setup a Restore Point; be patience! 6. The restore Wizard 7. Use (Recommended) Restore Point. Be patience! your computer will Shutdown, and Restart. *Note: Once the computer returns to Windows Desktop, do not perform any tasks, for at least (45 min) the System Restore is still running! *Conclusion: "Message successfully restored, or failed to complete restore? Follow “prompt message,” for further recommendations." "Helpful Ratings Feedback is appreciated,thanks paul7of9”
I have a HP a0310n desktop. I is rebooting in a
Well you can try in safe mode with command prompt and than
See if that works
I want to wipe the hard drive clean and then use restore disc to install the operating system. is this ok to do?hp dv6000 pavillion note book.i tried to restore system but keep asking for supplemental...
HP pavillion acting weird
system restore, your description sound like a brontok but hopefully not, just perform system restore, restore the PC to about a day or 2 before you installed AVG.
1.Click Start.
2.Point to All Programs.
3.Point to Accessories.
4.Point to System Tools.
5.Click System Restore.
6.Follow the instructions on the wizard.
once AGV is removed, you may try to look at NOD32 antivirus. its fast and great for my old computers too.
Unable to open some programs in my system
Have you checked your computer for viruses,or tried system restore?
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
