Question about Masonry Tools
Repair stucco siding - Masonry Tools
    Top Expert:
  • 30,351 Answers
6ya staff
SOURCE:
How do you fix peeling stucco on exterior of house.
Scrape everything off that is loose. See if there is any damage to the surface underneath, ie. rotted wood -cut it out & replace it. Spray the area with bleach if mold is present & dry. Once you have repaired the surface, coat it with bonding agent(cement area at Lowes or Home Depot) blue is better than white. Now get a bag of stucco and replicate the pattern of the surrounding area.(not easy) Stucco can be troweled on, splattered on, sprayed on, painted-on and in a huge variety of thicknesses. You may even need to trowel a base coaton to even out the surfaces to the surrounding area before you apply the finishing coat. When choosing materials take water proofing into account. Water damage is the usual culprit to stucco loss. Providing a better surface than what was originally there is recommended. Good luck.
Oct 09, 2015 | Cars & Trucks
If ProteShield is put on a beige colored stucco wall, will it dry clear, or will it darken the stucco when it dries?
Good question. Only way to know for sure with these products is to do a test on some out the way, unnoticeable spot, and test there for color change. Then be guided accordingly.
Aug 31, 2015 | ProteShield 1-Gal. Elastomeric Waterproof...
I have cracks in the stucco on my house, how do I patch it?
This is the car and truck section, but I can tell you there are products on the market for repairing stucco. Much the same as plaster repair.
You can check online or at one of the big box home improvement stores.
Jul 11, 2013 | Cars & Trucks
Cant get hose bib off pipe for leak replacement?
Follow it through to the inside and replace the length of pipe complete from rising main to the outside tap.
or
They are normally soldered on, so you need a blow torch.
You probably only needed a 5 cent washer, or gland packing in the top.
Dec 12, 2017 | Plumbing
How do i remove or dissolve caulk from stucco on side of house
use a wire brush,if that dos'nt work you might sandblast it.
Aug 05, 2011 | Garden
Since I have heard that Stucco should not be pressure washed at greater than 800 psi, how should I use my non-adjustable 1500 psi Karcher Washer for this job?
You can keep a greater distance from the stucco in order to not have the full contact pressure on the surface. Then if it is not doing a good job move closer to the surface. Another option is to buy a vario lance for your model.
Feb 25, 2011 | Karcher K2.26 Electric Power Washer
Because of broken (from a freeze) water pipes, I have a 2 foot by 4 foot hole in our outside stucco wall (a hole made by a plumber). I have cleaned out the hole, cut and placed plywood to match the hole,...
stucco really is easy. just go to HD or Lowes and get stucco patch. it is better to get the kind you have to mix yourself. Make a small batch according to the instructions and practice on a scrap piece of plywood so you get the feel for the material. You can lighten up on the water if the finish is rough. If the finish is smooth, then apply the stucco mix with the less water first and build it up until you have it about 1/8 to1/4 inch shy of the finished surface, then make another batch that has more water then called for to finish it out. PRACTICE on a scrap piece of plywood. Good luck.
Jan 27, 2010 | Bon Tool Stucco & Plaster Tools Co. Angle...
Error code 106, how to correct?
have you try to reinstall the software ??
You do it in this way, uninstall the software, reboot the computer and then reinstall the software.
If it still not work then return here :O)
have a nice day
please rate my answer
Oct 24, 2009 | Adobe Photoshop 6.0 for PC
How do you fix a leaking outdoor wall spigot? Even though the handle is turned tightly off there remains a drip. Spigot seems to be all one piece and attached into stucco wall. Is there a way to repair...
Sometimes, depending on the type of the spigot, you can unscrew the valve from inside the spigot. There would be a hex nut immediately under the part where the handle on the valve stem comes out. BE CAREFUL: Outside spigots rarely have independent shut-offs (ie, in order to work on it, you will have to shut off the main water supply). Once you start down this path, you need to be fairly certain there is a replacement available for your type of spigot. If you remove the valve, there is no assurance that you will be able to get the original back in without making the leak worse. Please have an emergency back-up plan in place.
Sep 16, 2009 | Plumbing
Waterproofing house stucco
First of all, this is a problem the guys from Home Depot wouldn't know how to fix.
Years ago, maybe when this post was originally written you may have needed to do a two coat system.
Your best and actually easiest option will be to power wash your stucco, to remove any dirt from the surface.
Then you will need to mask everything up tight because you're about to spray all the stucco. Cover any concrete and plants nearby, (anything that is closer than 10 feet from the stucco.)
Then go to Sherwin-Williams and purchase Loxon XP this is a one coat system however if you have larger cracks in the stucco you will either want to caulk them with an elastomeric caulk (if you don't have too many) or apply a second coat of Loxon XP. If you're a do it yourself kinda of person you can go to home depot and rent a spray machine. While your spraying your gonna want to back roll it. www.outbackpaintingusa.com
Oct 01, 2008 | Measuring Tools & Sensors
Masonry Tools Logo
161 people viewed this question
Top Masonry Tools Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Masonry Tool Expert? Answer questions, earn points and help others
