SOURCE: I have a toro lawnmower moel 20695 and whem i
check the gas line between the carb and bulb. Or it could be the plastic primer bulb itself. -a small tear or slice could easily go unnoticed.
SOURCE: the motor smokes and oil blows into the carberator
if you changed the oil recently you need to use SAE30 and not 10w30. Causes pressure buildup.
SOURCE: tire on toro lawnmower has de flated how do i re
the valve is on the inside. sometimes you can clean around the inside of the rim. to remove an dirt. also if it has set for long periods it may be dry rotted.. becomes very cracked on the outside of the tire wall.
