Sounds like you could have a bad mother board. Very common problem with the GE models. It will shut compressor off, than everything starts to melt, then it comes back on. Replace main control board and it should resolve your issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/keith_6cb11225ab437567
SOURCE: GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
SOURCE: The water line to my freezer flows fine. My
You need to replace the water valve. It is not sealing completely. Also make sure you have good water presure to the valve.
SOURCE: GE GSS22WGHMA freezer side will not freeze
changing temp sensors may cure problem (cheapest route first)
SOURCE: the water on the freezer
take a hair dryer a thaw out section behind the water outlet these units are junk.
