The only water leaks I know that appear inside a vehicle is normally from a bad heater core, but that normally leaks onto the floor of the passenger side. I would check your heater core regarding this problem.
look at water delivery tube to the ice mker . it has iced over and pluged up causing the water to go out the back and down on floor . . clear the water tube with hot water and problem is over . .. some models cah use a updated water tube. mm
We had same--water on driver side rear floor (soaked!). Driver side front floor seemed dry until feeling UNDER rug, was slightly damp. We found the location of TWO leaks causing this.
Leak #1 was through the parking brake line/cable seal; Recaulked with silicone. Removed plastic trim on floor between floor and door to reveal metal channel filled with water.
Leak #2 was where the door meets the car, near the hinge. It was the accordian-looking tube housing the wiring for the door. The big, rubber, circular plug connecting it to the main part of the car had come loose and water ran down through that, into the SAME metal channel filled with water from leak #1; will seal with silicone.
Note: We found that the channel filled extensively near the front door, BUT the carpet edge from the floor near the rear seat was dipping into it, wicking it up to the rear floor. Also, upon acceleration, the water in the channel gushed toward the back, thus soaking the rear carpet.
These leaks were found by removing all plastic trim (covering edges of carpet by doors), then one of us pouring water into specific areas of the exterior of the vehicle, and the other one watching closely with a flashlight for any signs of dripping.
Hi , Its leaking water on the passenger rear floor? It could be the heater core leaking and running down the floor board to the rear of the vehical. Do you smell antifreez or see moisture build up on the windshield ? does the car seem more "humid" inside?
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
The condensate drain is probably blocked. The water should exit under the vehicle. You need access to under the vehicle to remove the obstruction (could be a spider web or similar).
