SOURCE: Does anyone know what sy
http://www.retrevo.com/support/Frigidaire-FPHS2387KF-Refrigerators-manual/id/23613ag220/t/2/
Above is a link for your user manual. to download. copy past to browser.
manuals.frigidaire.com/prodinfo_pdf/Anderson/240389644.pdf
Above is the latest service sheet to do with your machine.
That SY ER is the SYtem EvapoRator Fault. This usually means there is NOT enough air flow over the sensor, this can mean a faulty sensor, or fan.. you need to check.
In my professional opinion you should get a service tech to call, contact your head or local Frigidaire offic, and ask them for a referral to an authorized service agent. When there then ask for a "Quote" as to the repair, this way you can make an informed decision.
usually though a repair such as this shouldn't be too costly, however it may just be the tip of an underlying condition, which is why i suggested the professional.
SOURCE: CODES ON THE FRONT OF
First thing to do is unplug your unit for one hour and then plug it back in to see if the control board will reset itself. If you are still getting the SY EF error codes then you will need to replace the controller board
SOURCE: What does "Sy EF" mean on dispenser led?
Error Code SY EF is the System Evaporator Fault.
this can mean a faulty sensor, or fan. Above is the latest service sheet to do with your machine, you need to check this.
Hope this helps (remember to rate and commnent this)..
SOURCE: My Frigidaire Gallery display says
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Hello Suzanne, thank you for your post!
I understand that your Electrolux refrigerator is displaying an error code of "SY EF". An "SY EF" code stands for an evaporator fan circuit failure. This could also be a miscommunication with your refrigerator and I would advise performing a reset on your refrigerator. You can reset it by disconnecting the power plug from the outlet for roughly ten minutes. If that does not help correct your issue you may need to replace your main control board or a wiring harness. For proper disassembly and repair of your refrigerator I would recommend having a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
