What kind of snake is black with diamonds on it's back.
It depends..... white diamonds make it a California King Snake. Dark brown to black chain like make it a Diamond Backed Water Snake. Or if it consists of a series of diamonds with an outer frame of white, an inner frame of dark brown and a mottled pattern in the center and a rattle, it's a Western Diamondback....... Where do you live?
SOURCE: i need cheats of snake game
We can not give out serial numbers for anything as it is Illegal and againt Fixya's policy.
Also there are no "game cheats" if that's what your looking for.
Sorry about any misunderstandings, thank you for choosing Fixya!
SOURCE: I have a proline 2hp above ground pump. A snake
The impeller is still jammed you need to get it cleaned out. You can try with a pair of needle knose pliers if that doesnt work your gona have to remove the pump bolts that hold the motore to the pump pod. Remove the bolts around the motor and seperate it this will give you better axcess to the impeller. Clean it out and try to move it if the impeller will not spin freely with the debris removed the motor has burned up .
SOURCE: ice on back wall of fridge
The ice forming on the back wall of your sub zero indicates that you have a part failure. I don't recall exactly what the part is but as soon as you mention your symptoms to a sub zero repairman he'll know your problem. It's an easy fix. Everything comes out of the fridge, takes the inside back wall off and replaces the part. Not an inexpensive repair, however the part is guaranteed for 5 years so you may have an opportunity to have it replaced under warranty as I did.
SOURCE: Can I use old newspapers as substrate for my snakes cage?
Newspapers are relatively good absorbents when used in several layers and is also a cheap option, however ink can be harmful for your snake. You should know that an animal who relies heavily on olfactory and ****** chemo sensation may be overwhelmed by the pungent odors of the inks, even the new soy-based ones.
SOURCE: What types of substrates are best suited for snakes?
There are some types of substrates that are preferred for snakes including newspaper/paper towel, reptile carpeting and aspen.
