SOURCE: roper washer top loader spins very slow
if the appliance has a induction type motor could be that the running capacitor is failing coul be the motor itself
SOURCE: I have a Roper brand
If the motor doesnt run during the spin cycle and the tub stays full of water. You need to replace the lid switch. This is very common problem. The part should be around 35 bucks. Easy fix.
SOURCE: i have a roper that spins but want drain
Your drain pump is clogged.
Remove the cabinet, remove the pump and remove whatever is clogging the pump.
The pump is located in front of the drive motor.
SOURCE: everything works-no spin-motor sounds like it won't engage
this is a whirpool style direct drive. most likely coupler is broken. it's a small part, between motor and gearcase about as big around as a silver dollar but thicker. lean the washer back so you can look under it and look right behind the motor. not a major repair. worth fixing. You will want to remove the cabinet so if you decide to do it mssg back for more info.
Machine will not spin but just makes a grinding sound instead.
