Razor E100 Electric Scooter Logo
N
Nate Atkinson Posted on Jun 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i flip switch to turn on it just starmts going full speed without touching throttle?
S350 electric scooter 24 volt
ebike
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Oct 26, 2014
 ebike
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
38398
Points
45
Unplug the throttle. If the motor still goes then the controller has a short and needs replacing
andrewcahoon
Level 2:
Habit-Forming:
  • Expert 79 Answers
  • Posted on Jun 15, 2014
andrewcahoon
Expert
Level 2:
Habit-Forming:
Answers
79
Questions
0
Helped
37876
Points
161
Sounds like the throttle is stuck in the full position. Can you adjust the throttle to other positions ? There should be a spring to return the throttle to a "off" position - and then you will have to twist to make it go. The spring may be missing.
EZip e-900 Electric Scooter. I have replaced batteries, Throttle, Control box, and motor and it still won't go.
Question edited for clarity.
Question moved from Cars and Trucks category.
The batteries, and throttle control could have been tested with multimeter. The motor can be checked with a multimeter and also with a power source (12 volt x 2 in series = 24 volts) or even with the battery pack that is on it. The only part that is difficult to troubleshoot is the Control Box and circuitry, but if the battery is okay for volts, the throttle passes power and the motor runs, it has to be the control box or connection wiring throughout.
https://www.google.com/search?q=EZip+e-900+Electric+Scooter
Just got a 2002I thinkxcaliber electric scooter. 24volt. Wanting to test the motor before getting a battery pack.
24 VOLTS is 24 VOLTS. 12 wont do the job. Also by running a battery not meant for that unit, you could damage it.
Feb 05, 2017 • Drills
Razor Scooter ground fOrce go cart wont go
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
1helpful
Please robin - try to understand - you tell me that the beeper is attached to the cable - i don't know where the cable is - don't tell me its by the controller - i don't know what the controller is or
the beeps are diagnostic beep codes and the sounder should not be disconnected,
count the number of beeps then refer to my chart.will tell you what problem is
2 battery voltage too low =fully charge min 8 hours
3 volts too high =contact dealer
5 scooter in freewheel or Brake trip=chech in drive then turn on
6 throttle wig wag faulty or not in center when turning key
7 throttle or speed pot wireing or faulty
8 motor faulty or wireing poor /disconnected
9 battery pack pads and terminals coroded .replace them £2 eachn from pride or controller faulty ..replace
Advisory the analog battery guages on these regulary go faulty and read over full get electrical friend to check battery volts 12.8 to 13volt =fully charged
How to fix my razor scooter e100?
The control module is simple and can be replaced with only a 24 volt relay without the kick start feature or Brake. If you want the brake then you can use two 24 volt relays still no Kick Start.
For those of you who know electrical, below is circuits I developed to replace the controller. This diagram will also give you a better understanding on the Razor circuit.
NOTE : This is not a schematic diagram of the Razor E100 Control Module. I designed this circuit. for my Great Nephew's Scooter.
1. The Brake is a normally closed switch that opens when you squeeze the Brake handle.
2. The throttle is two normally open switches that close when you turn the throttle.
3. The Kick Start circuit is described in the Diagram below.
4. The resistors values may need to be tweaked for best performance.
Google Link to what could be the Electrical Diagrams for E-100
How to fix Razor e100 troubleshooting
May 22, 2014 • Cell Phones
1helpful
No power
Battery razor e 100 replace
Wiring diagram for a reset button on a razor e-100 scooter
Batteries are fully charged. Scooter goes at full speed for approx. 1 block, then will slow to 1/2 speed and back up to full then back to 1/2. We have new batteries, checked for voltage at end of run, one...
Based on your description you have a bad throttle potentiometer or speed potentiometer. Remove the covers of the front console and check the resistance throughout the range of both pots at the connector. It should be even throughout the range with no dead spots. The newer CTE throttle pot is more reliable than the older model Celebrity scooter with the 5K ohm potentiometer. I usually replace the throttle and speed pots as a pair since they are connected electrically in the console.
Load test the batteries while you are driving. Using your voltmeter that is still connected under the rear cover while you are driving, check to see if you get a voltage drop of more than 1 volt. Static testing of batteries only tells you that there is a full charge. It does not give you an indication of how the batteries perform under load.
If you have clean brushes, you can still have a large amount of conductive brush dust in the motor and armature. Blow out the dust with compressed air. Check the motor and brake with you meter. The motor coil resistance should be less than 1.5 ohms and the brake should read between 40 to 60 ohms. Hope this helps.
Top Razor Toys Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Kardoc
Are you a Razor Toy Expert? Answer questions, earn points and help others
