How do I change flywheel key ? I have a toro flywheel walkbehind recycler. I think I sheared off the flywheel key how do I locate and change it
Remove the nut that holds the flywheel on.right hand threads.once the nut and starter hub is off the keyway will be visible.you can tell if it is broken then.if it isn't put the hub and nut back on.....problem somewhere else.if it is broken...take a small hammer and tap the flywheel on the oppisit side of the keyway.usually only takes a couple of hits from the hammer.once the flywheel is off the key comes right out of the crank shaft......replace the key,reinstall the flywheel.(some times you have to hold the brake off so the flywheel will slip all the way on shaft) install hub and nut.hope this helped,let me know........................
