MOWER RAN FOR AWHILE NOW IT WONT START AND POPS LOUDLY
SOURCE: Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
SOURCE: Craftsman 42 inch riding mower. Runs great
how old is your plug? try cleaning and regapping it or replacing it at any rate make sure it is gapped correctly also make sure there is no rust dust or debris is on flywheel or coil also the flywheel keyway does more than hold the flywheel in place it servs as a timing pin and sometimes the slightest wear on it can cause the machine to start hard but otherwise run great good luck hope you find the problem.
SOURCE: Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
SOURCE: possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
SOURCE: white smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
