DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Google that model number with ballast or lamp ballast to locate the part and its number. Usually the color wheel will not operate if ballast is not working---Lamp comes on and stays on the Ballast is good.
Is there any noise associated with the times that the unit flickers? Samsungs are notorious for losing the color wheel. I have replaced many and they usually make a high pitched whining sound. It could be high enough of a frequency that you may not hear it. If the lamp is new and the old lamp did not shatter or short out before you changed it I would say that the ballast is fine and I would change the color wheel. You will have to at some point as this is the weak point with the Samsung units. I have at tip at http://www.fixya.com/support/r4160054-replace_color_wheel_in_dlp_projection_tv which will walk you through the process as well as identify places to purchase the parts at the best price.
Thank you for using FixYa and for the great rating. Great ratings help keep experts solving everyone's problems. Thank you.
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Hi, Samsung haves a known issue with the ballast, once you make a replacement of the lamp, sometimes its harder to ignite a new lamp that has 100% of gas inside than igniting a old lamp that has maybe 60% or 50% of gas inside. Just in order to ignite the lamp, the ballast needs to send some High Pulses of Voltage, as high as 15 kV (that is the constant clicking sound that you are hearing). In order to resolve this you need to change the Ballast Board.
I tried to look for your ballast with your TV Model # at samsungparts.com , but nothing showed up.
You will need to find out which ballast part # you have in order to find it online. To locate the ballast part # please check the end of this video, you only need to take the lower back cover of TV off. http://www.youtube.com/watch?v=0jr_9A5Xd2Q
Here is a link of a ballast I found
http://www.discount-merchant.com/SAMSUNG-9137-008-08905-Lamp-Ballast-Driver-p/1138231.htm?Click=49915
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
