Water drips from tray creating "stalagtites" in the freezer; do I need a new ice tray?
Do the old 'KISS" thing first (keep it simple ......thing). Chances are that there are tiny calcium deposits in the ice tray which makes an ice cube stick in the tray. If one ice cube sticks, the water will overflow as it needs all the trays empty for the filling. The water will drip down into the freezer area causing chunky ice and stalagmites. The calcium deposits are very teeny in size but will hang up an ice cube from dropping. If more than one ice cube (basically all the ice cubes) didn't drop then the heater in that unit that initially gets the ice cubes to drop could be bad.
I've taken the ice cube assembly out and used vinegar with baking soda to dissolve the calcium and that worked. I left it in for a couple of days. "Do NOT" use anything like a knife or whatever to scrape the bottom of the tray as it will destroy the finish and keep the ice cubes sticking.
When I had the warranty service come out, the technician explained what happened to the tray (calcium). He replaced the tray but the next time it happened I used the vinegar and baking soda. I eventually bought a new tray for 1/2 the price on the internet when the problem happened later on in life.
SOURCE: Too much water getting to ice maker
The little cup that sits in front of the hose that dispenses the water, has frozen water in it . Check that first and if it's OK, then there is a small screw that you can adjust, look at your manual.
SOURCE: Kenmore Refrig 51562 Side By Side; Icemaker leaks water underneat
you are going to have to replacwe the solinoid valve for the icemaker mbecause its leaking by
SOURCE: Ice maker for Kenmore model 532343 not working
Does your water have minerals?
Faulty Water Valve
Your ice maker is designed to fill with water for 6 to 8 seconds. Check to see that the ice maker is not sending power to the water inlet valve for a period longer than what you unit is designed for. Does your water have minerals?
Also check to see if the water inlet valve is closing too slowly. The power to the valve is being shut off in the correct amount of time, but due to wear and tear in the valve, it is closing too slow.
Check the timing on the value. Put a volt meter across the leads of the water inlet valve. Set the voltage range to cover the 120v voltage. Cycle the ice maker and watch the meter. When the ice maker begins to fill with water the meter will read voltage coming from the ice maker. Time the difference between when the voltage is cut from the valve and when the water quits filling the ice maker.
If the water shuts off immediately when the voltage is removed, the valve is probably good. Since it was off 10 days the particle build-up on the valve may be the problem since it could solidify. You could try working the valve back and forth or replace it.
If the valve closed quickly then the problem is the valve was opened too long.
If that is the case then you have an ice maker control problem. In that case see if the timing can be adjusted.
SOURCE: Kenmore 106 50522 water leak from Icemaker
Hi: Usually if the ice maker malfunctions that bad it will keep running and flood bad. If your defrost drain is plugged it will puddle water. Without knowing how much water you see it is tough for me to say precisely. Does the ice bin have a big block of solid ice or cubes? If cubes I would guess it is the defrost drain at the bottom of the fridge. If the drain is clogged the water wont get to the pan to evaporate. If the defrost water has nowhere to go it will puddle. This would produce more water on the floor in a humid area than a desert like I live in. If so look at the bottom of the freezer in the back below the metal panel. Usually there are slots above it. There will be a hole at the bottom of a shallow rectangular funnel. Turn off the fridge and put your food in a cooler. Pour some warm clorox water in the hole, a fairly strong solution. It should eat out the mold that grows in the base of this non refrigerated line. If something like a frozen pea got in the line you might have to use a pipe cleaner to snake it out. Good luck with this, Jeff
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
