Question about GE GSS25JFM Side by Side Refrigerator
How many cubic feet is GE model GSS25JFMC?
I'm wanting to know if this GE model fridge is 25 cubic feet. I'm guessing that it is 25 since that is part of the model number, correct?
Anonymous
SOURCE:
Anonymous
  • 58 Answers
SOURCE: need to find model # for ge monogram 42" side-by-side (1992?)
on the 42" Monograms the Model & serial nomenclature are usually located behind the top panel in the center section to the right of the compressor panel. Hope this helps....Bill
Posted on May 18, 2009
smartr10U
KEN LaPOINT
  • 1305 Answers
SOURCE: How many cubic feet is my old Hotpoint Model
Easy to measure. Height x depth x width = cubic feet.
Posted on Jun 08, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: what is the cubic feet of gts18fcsarww
18 cu ft . Look familiar ?
Posted on Oct 10, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: my ge side by side model gss25jfmc ww will start
I can tell you how to find the problem , but , it is a little work .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and , when to cycle off due to temp satisfied .
Posted on Jan 02, 2010
BElectric
DILLIGAF
  • 1140 Answers
SOURCE: I have a GE Profile
Hi -
The TFH22 has a nominal size of 22 cubic feet total capacity - 21.7 cubic feet if you need to be exact. The fridge:freezer size split is 60:40, but the ice-maker reduces the capacity of the freezer, so the capacity is split as follows:
Fridge capacity: 14.5 cubic feet
Freezer capacity: 7.2 cubic feet.
These figures are correct to within +/-0.2 cubic feet for each. If you need to be more exact, you need to call GE as they no longer publish these specifications. The manual covers the 22, 24 and 27 cubic feet models, so the individual specifications for each one are not included.
Hope this helps. If you need further assistance, you can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Posted on Apr 30, 2011
HOW MANY CUBIC FEET ARE IN MY GE PROFILE REFRIGERATOR TBX22PRBMLWW
Hello Terry Montag,
I would be guessing 22 Cubic Feet...
(and give odds)...!!!
Generally the 22 is a biggie in your MODEL numbers...
Like the "WW" typically means Wreally WHITE...
and "SS" means stainless steel.
In my less than HUMBLE opinion).
Carnac the Magnificent
Apr 07, 2017 | GE Refrigerators
What is the cubic feet equal to 30" x 25" ?
You need three dimensions for a volume.
30 inches by 25 inches is 750 square inches or about 5.21 square feet.
Sep 14, 2014 | Office Equipment & Supplies
How many cu ft is a GE GSH25KG refrigerator?
it is 25 CUF, but if you have it already, why do you care? :-)
Jul 20, 2014 | GE Refrigerators
What is the cu ft of Model FRT21IL4FW3 Freezer space?
Easiest solution is to measure the inside dimensions in inches, tall, width and depth. Then multiply the three dimensions t x w x d = cubic inches. To get cubic feet then divide the above answer by 1728 and the result is cubic feet..
For instance if the fridge is 60 inches tall x 24 inches wide x 18 inches deep; the answer is 60 x 24 x 18 = 25,929 cubic inches... 25,920 divided by 1728 = 15 cubic feet.
Jul 12, 2014 | GE GSH25JSTSS Stainless Steel Side by Side...
How many cubic feet is my ge fridge, TFX25JP?
The first few numbers in the model number indicate the cubic footage...so that refrigerator is 25 cubic feet
GENE
Sep 08, 2011 | GE Refrigerators
Hi there, I need to know how many cubic feet is this fridge: HotPoint hss25gfpjww
The 25 in the model number means that it is 25 cubic feet.
Feb 26, 2011 | Microwave Ovens
Cubic feet in a GE MOdel TFX22KRCE WW
If there is nothing inside the refrigerator that will tell you its cubic feet, you could always calculate it on your own. See this link:
http://www.ehow.com/how_4530599_find-cubic-feet-refrigerator.html
Jun 17, 2009 | Computer Gear Fridge Gears Puzzle
GE GSS25JFM Side by Side Refrigerator Logo
148 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
Vish Iyer
Vish Iyer
