Excessive use of chain oil
Unlike most bigger gasoline powered chainsaws, the Ryobi RCS2040 electric chainsaw does not have an oil adjuster. The oil pump on it is pretty much a simple mechanism that moves the oil on a "cork screw" -it rotates when your chainsaw runs, then your oil glides out of the reservoir into the tube towards the chain oiler. Amount of oil used will depend on two factors: 1.) Type of oil used. We sell winter grade and summer grade (but we are in Southern California, this doesn't make any difference). Our customers prefer the less tackier ones because it doesn't burn their bars under heavy use and it is less strain on the unit, however this drips out fast. 2.) Integrity of your oil line system, and the size of your reservoir (on your model, it IS small). Our rule of thumb here is that if it drips bar & chain oil, it's working. Well, that is unless it's leaking someplace else other than the bar oiler. Check the oil tube - it should be on the bottom of your chainsaw right on the same side as the oil tank.
Generally, speaking for both mid-sized electric and gas powered saws - 45 minutes of worth of cutting should have your bar and oil tank depleted already. Our contractor customers even have it opened way up.
