SOURCE: Poulan Pro lawnmower (Briggs and Stratton 128 cc
IF IT IS A BRIGG & STRATTON ENGINE YOU CAN GO ONLINE TO BRIGGS & STRATTON.COM AND ASK THEIR TECH SECTION ABOUT THE PROBLEM. FOR 3 MONTHS OLD SOUNDS LIKE DIRT OR WATER MAY HAVE GOTTEN INTO THE TANK. WHEN YOU PRIME THE MOWER YOU ARE FORCING GAS INTO THE CARB AND ENGINE AFTER THAT THE ENGINE SHOULD PULL THE GAS IN THE ENGINE, I WOULD SAY THE CARB MITE NEED REBUILDING BUT NOT AT 3 MONTHS
SOURCE: Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
SOURCE: where are the oil drain plugs for a poulan pro 550
under the deck above the blade. It is probably a square head pipe plug
SOURCE: Poulan 550 Series push mower won't pull start
Poulan 550 series self propeeled mower. Mower starts and stops running after 10 seconds. Gas tank full. Filter cleaned.
SOURCE: poulan pro w/ 550 series
Your carburetor needs a good cleaning or a rebuild kit, depending on its condition once opened up. There are tiny holes (jets) in there that easily get clogged or gummed up with today's crappy gas (ethanol). This is the problem with 90 percent of the machines I work on or fix. If you don't know carbs, then I recommend you take it to a professional and have the carb done (30 to 40 USD, probably), but it should run like new, once this is properly done. If you are a "do it yourselfer". then you can find plenty of videos on youtube to help you get started. Just pay close attention to what goes where when you take the linkage apart. Trust me, do not leave it to memory; take photos. Best of luck to you.
Testimonial: "Much appreciated. Giving me an idea of what to look for as well as where I can go for further information is extremely helpful. Thanks. -Jake Towley"
