Husqvarna HU625HWT wont run witth a briggs and stratton motor
SOURCE: I can start my 4.75 HP Briggs & Stratton
Try replacing the float and needle. The float (floats) and pulls the needle up to let gas through to the carb. It will stay running as long as you press the prime bulb because this sends gas straight to the carb without going through the gas bowl. It's best to remove the carb and clean it then replace the float and needle
SOURCE: Craftsman Mower - 625 Briggs
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
