Why will my Poulan Pro PO16542LT riding mower only go forward and backwards when clutch is engaged but when clutch is released it stops moving?
It sounds like there may be an issue with the drive belt on your Poulan Pro PO16542LT riding mower. When you engage the clutch, the belt tightens and provides power to the wheels, allowing the mower to move forward or backward. When you release the clutch, the belt should become loose and the mower should stop moving.
If the belt is loose or damaged, it may not be providing enough power to the wheels when the clutch is engaged. This could cause the mower to move slowly or not at all. When you release the clutch, the belt may not be loose enough to completely disengage from the wheels, which could cause the mower to continue moving slowly or even stall.
To check the drive belt, you'll need to consult the owner's manual for your specific model of mower. The manual should provide instructions for inspecting and replacing the belt if necessary. Alternatively, you may want to take the mower to a professional for repairs if you're not comfortable working on it yourself.
