SOURCE: washer agitates but doesn't spin or drain
something in your pump lean it back take hose off drain pump and clean it out
SOURCE: Kenmore 2.1 cu. ft. Portable Washer - won't drain
Probably something caught inthe pump. Will have to remove pump and take obstruction out. Only other thing I can think of is the pump ran tight and would have to be replaced
SOURCE: washing machine suddenly stopped working during cycle
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
SOURCE: I have a Kenmore washer model 417.44072300. I
3.4 cu ft.
SOURCE: what cu. ft washer in
you can find out by measuring the depth of the tub in inches. Measure the diameter of the tub at the opening where you put the clothes in. Multiply those 2 numbers. Then divide the figure by 144 which is a cubic foot in inches. That will Give you the cubic feet.
Example Depth of 23 inches and diameter of 21 inches. 23X21= 483/144 = 3.35 cu. ft.
