Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
Posted on Jun 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove drain plug from garbage disposal
  • Official Brand Answer 2,267 Answers
  • Posted on Jun 12, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1288913
Points
2557
Good Afternoon Dogman85,
I understand you want to know how to remove the drain plug from your garbage disposal, regarding your Frigidaire dishwasher, model# PLD2850. I suggest contacting the manufacturer of the garbage disposal. They will be able to better assist in removing the drain plug from your garbage disposal. Hope this is helpful.
-Best Regards-
WP
5 Related Answers
bluegreenash
Gareth Cockram
  • 661 Answers
  • Posted on Oct 09, 2007
SOURCE: Not draining...hose clear
not really, it sounds like you have done all the basics,
Anonymous
  • 5911 Answers
  • Posted on Apr 08, 2008
SOURCE: How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Anonymous
  • 1073 Answers
  • Posted on Apr 30, 2008
SOURCE: Dishwasher won't drain
remve the drain line connected to the garbage disposal take a flat blade screwdriver insert it into the garbage disposal and hit the end of the screwdriver , the plug will pop out
to verify after hitting it stick the screwdriver back in if it has not removed the plug do it again
Anonymous
  • 5911 Answers
  • Posted on Oct 13, 2009
SOURCE: How do you knock out the plug in garbage disposal
From the outside of the disposal, insert a large flat blade screwdriver and give it a hard tap with a hammer. The plastic plug will pop free. Reach inside the disposal and retrieve the plug. If you have questions, please let me know.
Anonymous
  • 414 Answers
  • Posted on Jul 08, 2011
SOURCE: my garbage disposal got plugged up then my
The disposal has a port that connects to the dishwasher. If the disposal clogs, the dishwasher cannot drain. There should be a 5/16 hex hole in the center of the underside
of the disposal to use a "wrenchette" disposal wrench to free the disposal. Or just use a
5/16 allen wrench. After freeing unit up, push the red square reset button on the bottom of the disposal. It should now work at the switch.
On some smaller disposals you may need a "universal"
disposal wrench that works from the top of the disposal. The reset is still located on
the bottom of the unit though. They cost around 10 dollars at the home improvement
store. Hope this is helpful.
1helpful
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
2answers
We just replaced our garbage disposal and now the dishwasher won't drain. I order a drain pump and it still won't drain.
Make sure that the air clear on top of the sink is clean and clear all the way through. Sometimes in replacement silt and other garbage clog this up and keep it allowing water to drain properly.
Dishwasher will not drain totally after it has finished the cycle. I recently had a new garbage disposal installe and every since then the dishwasher will not drain. Is it something to maybe do with the...
disposal has a plug in it where the drain line from d/w hooks up remove drain line from disposer and stick a screwdriver in hole to remove plug remove plug from inside disposer with a pair of needle nose pliers that should take of it
Oct 26, 2009 • Dishwashers
41helpful
2answers
Removing dishwasher drain plug on a new garbage disposal.
The plug is thin plastic. Use a flat blade screw driver and a hammer to knock it out. I know this sounds primitive but this is how it is done. I have been a plumber for thirty years.
My quiet partner 4 will no longer drain, I recently replaced my garbage disposal & the problem began after that.
There is a plug you have to remove on the garbage disposal where you hook up the washer drain hose.
Check the instructions with the disposal.
You'll have to deinstall the garbage disposal, remove this plug and reinstall.
May 05, 2009 • Dishwashers
Not draining
Did you remove the plug in your disposal so the dishwasher can drain???
62helpful
Kenmore Built In Dishwasher
the obstruction they talk about in the disposer, its where the connection for the d/w drain is made, there is a "knockout" plug within the drain line connector( in case you dont have a d/w) that would need to be removed before the d/w will drain. can be popped out with a good smack with a screw driver, the plastic knockout will land within the disposer. disconnect power and remove the plug, it will not break up and wash away
2answers
Dish washer
The drain in to the garbage diposal is clogged.  Remove the drain hose from the dishwasher and clean the hose.  Also check the inlet to the garbage disposer and clena it.
Oct 28, 2007 • Dishwashers
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
