Spark plug gap for poulan pro ppb250e - Poulan Pro PR550N22SH 22Inch Briggs Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) ()
First and foremost ppb330 is a model number for a grass line trimmer, gas model.
Second, I am unsure what you are asking. Gap coil?? Do you need the spark plug gap for your chainsaw? That gap is .025.
I hope this helps. If not, please re-post with the correct model number for you chainsaw.
Go to the following site where you may well find parts needed
http://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/poulan/hedge-trimmers/pp2822-966513101-2011-03/engine
Replace with Champion CJ-7Y or RCJ--7Y spark plug and tighten securely with a 3/4 inch socket wrench. Spark plug gap should be 0.025 inches R stands for resistor on the RCJ-7Y. Either plug will work. PDF of Owners Manual If you have other questions about your saw, there is an 800# at the top of PDF. Hope this helps.
re: "The plug should be set from the factory check your manual for the gap setting" Chris, If people had the manual do you honestly think they would waste their time looking for the answer online. Chris - I hope you don't get paid for offering 'Check your manual' answers.
Spark should jump at least 1/8 inch gap.You would need the correct coil for the application spaced at 10 to 12 thousands inch.
You might unplug shutoff wire and try,it might be shorted a lttle causing weak spark.
