Health & Beauty Logo
discgolftrainnut Posted on Jun 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I find wiring diagrams for a Quantum 600 power wheelchair and a Quantum Blast power wheelchair?
Lawrence Oravetz
Level 3:
  • Pride Master 10,558 Answers
  • Posted on Feb 24, 2015
Lawrence Oravetz
Pride Master
Level 3:
Answers
10558
Questions
Helped
2697279
Points
29284
The service manual from the manufacturer's website has the wiring diagram in it You can download it.
1 Related Answer
Anonymous
  • Posted on Jul 14, 2011
SOURCE: Jazzy Quantum 600 power wheelchair - On the
THE WHEELCHAIR WILL ONLY TILT IT WILL NOT GO FORWARD OR BACKWARD USING THE JOYSTICK
Code 208 on my quantum 600 edge 3
This appears to be a Mobility Power Chair Base rather than a Cellphone question, so I moved the category.
It looks like you may have a loose connector. The error is a brake related error
Error 208
Brake No. 1. Overload: current too high
Brake wiring shorted, or brake defective.
Check motor brake connector.
Check brake wiring.
Check brake resistance.
Replace brake.
https://www.alliedmedical.co.nz/media/6385/qlogic-1-and-2-fault-codes.pdf
and
https://www.google.com/search?q=quantum+600+edge+3%2C+code+208
How do you power cycle the Quantum Q6 Power Chair?
Owner's Manual - Quantum Rehab
https://www.quantumrehab.com > owners-manuals
PDF Including Models: Q6 Edge HDTM, Q6 UltraTM, and Q6 Edge ZTM ... product, this icon is represented as a black symbol with a red circle and red slash. ... instructions in this manual and those located on your power chair can lead to personal ...
Basic Troubleshooting Instructions ' Quantum Rehab ...
https://www.quantumrehab.com > resources > quantum-...
... troubleshooting instructions as they pertain to our electric wheelchairs and other power wheelchair accessories. ... INFINFB2594 Q6 Edge Troubleshooting.
Or contact the company direct.
Quantum 600 power wheelchair. From time to time chair stops abruptly, low battery appears on controller screen even though battery is fully charged.
There is a 51 page MANUAL here:
Quantum 6000 Owner Manual
See this link for 1,500 Troubleshooting results:
quantum 6000 wheelchair troubleshooting Google Search
You may be looking at a sudden/intermittent electrical short OR one of your connectors may be loose?
http://www.thewiringbooks.com/wiring/quantum-6000z-wiring-diagram.html#gallery-1
Your chair voltage REGULATOR may also be going bad which appears to be WITHIN the "Main Brain" of your chair?
"TECO FM-50"
regulator-gkhd23p0qwnavtoilob1hbhw-1-2.jpg From the above schematic ~ there is a "Potentiometer" shown (lower left) that MAY be 'dirty' and needs a tiny squirt of "QUALITY" contact cleaner WITH SILICONE to help keep the internals clean... looks something like this (a Google Search):
I would also spray ALL of your control switches too including the inside of your joystick controls! Just a REAL QUICK squirt should do it... if it drips, you've used too much.
I hope this HELPS YOU!
Anthony
My quantum 600 wheel chair won't work it says system lock
My quantum 600 wheel chair won't work it says system lock ...
www.fixya.com/.../t26033304-quantum_600_wheel_chair_work_says_s...
2 hours ago - My quantum 600 wheel chair won't work it says system lock -Wheelchairs question.
Pride Mobility Quantum Q6 Edge (Power Wheelchairs ...
www.usatechguide.org/itemreview.php?itemid=1626
Quantum 6000 or 600 Rehab Power Wheelchair - CareCure Communitysci.rutgers.edu/.../showthread.php?...Quantum-6000...Rutgers UniversityJul 4, 2008 - 10 posts - ‎9 authorsI had the QUANTUM 600e Rehab Power Wheelchair for six months. ... C-500 Hvy dutypower chair w/hi-speed motors, power seating system, .... I have a Q600 with tilt, recline, leg extension, Q-logic..pretty much the works. ... the thing shuts itself off andwon't move when I have anything under 90% charge?Quantum® 600 Power Chair Reviews - Pride Mobilityownersclub.pridemobility.com/reviews/item/1/20The Quantum® 600 Power Chair delivers the stability of patented Mid-Wheel 6® ... At that same time the 3rd motor set was changed my seating system was ... We were rescued by boat and my friends say the wheelchair was working ... Insurance won'tcover a power chair for me yet so I had to pay out of pocket for this one.
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
