I have a side by side refrigerator from Blomberg company.today i saw on touch panel that indicate "i" indicator and temp of freezer was flasher and saw error code E4 after each flasher...pls help me to solve that
E4 error code on a Defy Refrigerator is a indication that there is something wrong with the air movement inside the freezer compartment.
REASON for code
The freezer has made too much ice and is now all frozen-up or
it could be that freezer system is low on refrigerant (gas)
Possible Causes
1. The freezer door wasn't closed properly - just closed enough to switch off "door open" alarm and open enough to let moisture in - resulting in over condensation on condenser.
2. Abnormal high open and closing of freezer door.
4. Defrosting Element not heating - therefore not melting the ice - buildup
5. Pc control panel has gone on the blink
6. Refrigerant tubs has rusted causing a gas leak.
I hope this has helped you to make a more informed decision about your next step.
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure Disconnect for one minute - if error comes back, replace control board F1 - Shorted control keypad Replace keypad F3 - Oven temperature sensor open Replace oven temperature probe F2 - Oven temperature sensor shorted Replace oven temperature probe F3 - Oven too hot Replace oven temperature probe F3 - Clean temperature too hot Replace oven probe F5 - Door latch switch fault Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop) Replace control board F2 - E0 - Shorted control keypad Replace keypad F3 - E0 - Oven temperature probe open Replace temperature probe F3 - E1 - Oven temperature probe shorted Replace temperature probe F3 - E2 - Oven temp too high Replace temperature probe F3 - E3 - Clean temp too hot Replace temp. probe F5 - E0 - Check door latch F5 - E1 - Check door latch Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error Replace ERC F1 E1 - EEPROM checksum error Replace ERC F1 E2:7 - UL A/D errors Replace ERC F1 E4:2 - Model ID error Reinsert keytail. F1 E6:0 - Latch signal mismatch error Replace ERC F2 E0:4 - Shorted key error Replace keypad assembly F2 E1:3 Keytail unplugged reinsert the keytail F3 E0:5 Top oven sensor open Test and replace top probe. F3 E1:6 Top oven shorted Test and replace temp probe F3 E2:9 Bake range over temperature Test and replace temp probe F3 E3:8 Clean range over temperature Test and replace temp probe. F3 E4:10 Bottom oven sensor open Test and replace temp probe F3 E:15 Bottom oven sensor shorted Test and replace temp probe F5 E0:14 Door switch errot Test and eventually replace door lock switch F5 E1:16 Door latch not operating Test and eventually replace door latch F8 E0:17 Refrigeration error Test the cooling module. PF Power failure - Does not indicate a fault. PF occurs when power is disconnected.
WHIRLPOOL Models SF3, 30'' and 24"
F2 - Oven temperature above specifications Check 8-pin connector from temp. probe to Electronic Oven Control F3 - Open oven temperature probe failure Check wiring, replace oven probe if necessary F4 - Shorted oven temperature sensor failure Check wiring harness, replace oven temperature probe if necessary F5 - Push button stuck or faulty Check for binding of pushbuttons and control panel glass. If OK, replace touch panel F6 - Electronic control logic error (timing) Replace Electronic Range Control (ERC) F7 - Electronic control logic error (lock motor) Replace ERC. F8 - Electronic control logic error Replace ERC.
Water inlet valve is not working properly. either not letting water through the valve the first time and now it is sticking open and letting water over fill. Replace water inlet valve.
E4: Indicates lack of refrigerant, or the compressor is not running, or the thermistor is out of
calibration.
Action: Check that the compressor is running by listening.
If it is apparent that the compressor is running, then check the
temperature difference across the evaporator.
i.e. Measure temperature of return air at inlet filters and
measure temp. of discharge air at grilles. This temp diff.
should be 14 to 18 C. with fan on hi speed. If temp diff. is less than this,
suspect lack of refrigerant.
Fit a suction gauge to access valve at rear of unit. See fig 12. On a 35C
outside temp. then suction should be 380 to 450Kpa.
E4 error indicate an abnormal water level which means too much inlet water (E5 also is refer at this fault).
I quote other comments/solution about this same error: ----------------------------------------------------------------------------------------------------------------------------------------------------- I had the e4 error code and i took the outer panel off and inside behind
the power button is a grey reservoir tank which measures the water that
goes inside the dishwasher which actually got bunged up with **** and
grease causing the floaty thing to get jammed and cause the e4 code to
come on which means abnormal water level the top to the reservoir just
unclips on both sides then just clean all the gooey stuff out and put it
back together it worked for me. -----------------------------------------------------------------------------------------------------------------------------------------------------
The error code E4 indicates that ur printer is low on black ink if ur getting this error error code then u need to replace the blak ink cartridge. Hope this solution will solve ur prob
