Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
A
Anonymous Posted on Jun 09, 2014
What replacement belt do I need for Briggs Stratton 650 self propelled
Clyde Ottaway
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Briggs & Str... Master 1,669 Answers
  • Posted on Sep 04, 2018
Clyde Ottaway
Level 3:
Loyalty:
Answers
1669
Questions
41
Helped
490043
Points
2465
Check on partsTree Repair Clinic
1 Related Answer
Anonymous
  • 252 Answers
  • Posted on Aug 08, 2010
SOURCE: i need a replacment drive belt for murray
hi
please find web site for parts and id of your belt
http://www.partstree.com/parts/?lc=murray&mn=20615x51A+-+Walk-Behind+Mower+%282000%29
part number is ref number 28 in the diagram
& murray pt number 037x99
partstree site is good site
cheers paul
2answers
How do I change the belt on a Briggs and Stratton Self Propelled 7.25ex lawn mower
unbolt top cover 5/16, unbolt bottom cover 3/8 unbolt blade 9/16 or 5/8 remove old belt, install new one, install covers and blade
Self propelled lawn mower makes whinning noise
disconnect the spark plug turn the mower on its side and inspect the drive belt on the pulley above the blade (on the crankshaft) it may have a shroud over it. Also there is a small gear case that maybe dry that the belt drives, that goes to the wheels, Also try lifting the drive wheels up off the ground and engage them and see if it still does it. if it stops once lifted it might be the bushings on the axle its self.
How do i change the oil on a 550 briggs and stratton small engine
Should be a drain plug on the bottom of the motor remove it drain the oil replace and refill
What oil do I use for a briggs and stratton 650 series
Any good grade of SAE 30 will do fine unless on cold weather operation..then SAE 10-30 ..
Belt jump off the drive pulley
I don't have this kind of mower. But I was faced with the same problem recently. I got my belt back on by taking a large wrench and affixing it to the bolt head holding the pulley which you want to slip the belt on. Hold the belt firmly against the pulley and turn the wrench and the belt in the grove will walk around the pulley until it slips in place.
2helpful
My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
ACCELERATOR HAS STOPPED WORKING ON BRIGGS & STATTON PETROL MOWER
when the lawn mower suddenly stop working,first you should check the fuel. i think the Self-propelled device was broken. You can take the Self-propelled device off and try again with it.
Top Briggs & Stratton Garden Experts
Jay Finke
Jay Finke
john h
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
