Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
Posted on Jun 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code if err for kenmore elite model 795 77563600
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 27, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5034625
Points
35540
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Kenmore F35 error. Unit on washer drum that connects to the water level sensor has a pin hole and is leaking.
If you find a tear in the hose or loose connection in the air pressure tube, then this is the likely cause of your F35 error code. If the air pressure tube appears to be okay, then you will likely need to replace the analog pressure sensor.
Jul 21, 2015
What is the error code F-35 - Kenmore Elite HE3 Washing ...
Replace the parts, or block the hole with waterproof epoxy putty.
Model # 11047789701 Official Kenmore Elite washer
Sears PartsDirect https://www.searspartsdirect.com > model > kenmore-e...
Here are the diagrams and repair parts for Official Kenmore Elite 11047789701 washer, as well as links to manuals and error code tables, if available. Continue .
How to run diagnostic on Kenmore elite smartwash quiet pak 9 HE4t washer? Model#110.45087401
Diagnostic mode for Kenmore Elite He3t model 110 42926 ...
iFixit https://www.ifixit.com > Answers > View > Diagnostic...
Apr 8, 2016 - With the washer empty, close the door. · Push "control/on" or "Start" · Select "Drain/Spin" · Select "No Spin" by pressing SPIN SPEED touchpad.
3 answers · 2 votes: I believe this is very similar to the model I have. Here is what I did to run a diagnostic. ...
F11 error code during Diagnostic test? - Kenmore ...
1 answer
Jan 18, 2016
SOLVED: F11 code error on Kenmore HE3 - iFixit
Mar 3, 2011
SOLVED: f h error code - Kenmore Elite HE3 ...
Feb 21, 2012
It seems like the washer has no power - Kenmore Elite ...
Nov 2, 2017
More results from www.ifixit.com
Diagnostic Test; Starting The Test Mode; Test Program ...
ManualsLib https://www.manualslib.com > ... > User manual
Close the door. Select the DRAIN/SPIN cycle. Select NO SPIN by pressing the SPIN SELECT button five (5) times. Push Prewash Option button four (4)times within ...
Kenmore elite washer model 11045087 400 err code hl f?what is this
Go on internet and go to Kenmors , and then from there on kenmore's website say need area code 400 for Kenworth washer model 11040 87 that should help you
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 • Dryers
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
I have a sears kenmore elite slide in range model number 790.46613500 that has a f13 err can anyone help with this
Unfortunately, the F13 error indicates that the oven control has failed. First unplug your range and wait 30 seconds or more to reset the code.
If the error recurs, this part will need to be replaced. See http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Range-Parts/Model-79046613500/0583/0124160/R0507023/00001?blt=06&prst=0&shdMod=79046613500 for the parts list.
I'm not exactly sure if your unit needs part 97 or 97A.
I hope this helps.
Kenmore Elite ER FF
Possible sesor error. Unplug for bout 10 min then plug back up.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
