The hour meter comes on when trying to crank. I replaced battery and trickle charged it and have had no trouble with mower until now. There is no sound from stater or anything when turning key. I sit on mower with brake fully engaged.
SOURCE: craftsman riding mower model 917.270921 put on a
What method are you jump starting? Are you putting clamps from jump battery on the posts of the battery or grounding the jump battery and then touching the + cable to the starter terminal?
SOURCE: Murray 17.5 HP mower - no noise when turning key? Maybe ignition?
Look near the starter solenoid for a fuse. It is probably under the hood near the steering column. If fuse is good, problem is likely a safety switch.
SOURCE: I have a Sears 26 hp garden tractor that stalls
does it run off of a pto system or is it a lver type if its a lever type there is a switch under the lever also you might have something caught in the deck causeing it not to engage blades if i can further help e-mail me wade at [email protected]
SOURCE: 18.5 hp 42'' mower model no. 917.274811.Mower will
ck the terminals battery, solenoid. are they clean? and tight?
SOURCE: i have a bolens 38 inch riding mower. it cranked
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Testimonial: "thanks. at least i can crank it and get it to a trailer instead of pushing it. i really appreciate it.......cb"
