Question about Whirlpool Inglis IP8200 Dryer
Do you have a digram to show you how to change belt on inglis dry
INGLIS DRYER HOW TO REPLACE BELT
  • 10,865 Answers
do you have a digram to show you how to change bel - amana.gif Diagram A
Style: Flat with ribs
Installation Tips: Ribs face toward drum
do you have a digram to show you how to change bel - transparent1.gifploads/images/do you have a digram to show you how to change bel - frank.gifnt1.gif" alt="transparent1.gif" class="h_mi" /> frank.gif Diagramdo you have a digram to show you how to change bel - transparent1.gifb>Style: Fldo you have a digram to show you how to change bel - frig.gifribs
Diagram C
Instaldo you have a digram to show you how to change bel - transparent1.gif Ribs face toward do you have a digram to show you how to change bel - maytag.gif transparent1.gif ge.gif Diagram E
Installation Tips:do you have a digram to show you how to change bel - transparent1.giff belt against drum Diagram F
Installation Tips: Ribs against drudo you have a digram to show you how to change bel - belt2.gif transparent1.gif Diagram G
Style: Flat belt
Installation Tips: Side of belt witdo you have a digram to show you how to change bel - belt4.gifaces away from drum
transparent1.gif whirlpool.gif Diagram H
Installation Tips: Ribs against drum
belt1.gif Diagram J
belt2.gif Diagram K
belt3.gif Diagram L
belt4.gif Diagram M
Posted on Jun 25, 2009
6ya staff
SOURCE:
Inglis dryer is squealing like a belt loose. it subsides during cycle but a burnt rubber smell is very prominent when finished
Replace the belt - it is old and worn out. The belt is made of rubber and is slipping, causing the smell and squeak. The belt heats up and becomes more flexible after the dryer runs a while; this is why the squealing stops.
Mar 26, 2013 | Inglis 6.5 Cu. Ft. 5-Cycle Electric Dryer...
How do you replace the belt on a whilpool dryer , is there a video available
1) remove filter
2) remove 2 screw from top of filter housing
3) pop the top
4) remove front panel
5) remove drum and clean the dryer
6) oil the rollers
7) oil the idler
8) place drum back with belt
9) Insert idler in floor
10) install the belt by passing it through the idler and looping it onto the motor. Turn the drum a few rounds to make sure the belt is not twisted then re install the front.
Here is me in my movie I made that shows how:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 12, 2012 | Whirlpool Inglis IP8200 Dryer
How to change belt
They ain't made no belt driven washers in years at Inglis. That guy has a drive coupling.
Check this video out:
How it works: Direct Drive washer
Topslosher's 101 service manual and videos are HERE
Feb 03, 2011 | Whirlpool Inglis IP4400 Washer
What's the correct drive belt configuration on an inglis front loading dryer?
I think you're requesting info on how to route the drive belt, aren't you ?
If that is indeed what you're wondering, the image I've attached should help. It is the Whirlpool/Kenmore image you'll want to go by, Inglis is Whirlpool.
If not please let me know and I'll see if I can assist you further. If this does answer you're question please allow a second to rate the info I provided here.
Thank you for visiting "fixya" and good luck.
macmarkus :)
Apr 10, 2010 | Whirlpool Inglis IP8200 Dryer
Whirlpool Inglis washer super capacity, 8 cycles, 2 speeds. Bought in May 2008. Works well and washes well, but it is VERY loud and seems to be getting louder and now there is a faint rubbery smell when it...
I received an Inglis Washing machine from soneone on freecycle. They thought the belt had broken, doesn't have a belt, it's gear driven. I'd bet the noise you hear is the coupling going out, (rubber). Good luck.
Jun 11, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpool Inglis IP8200 Dryer Logo
2,794 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
