SOURCE: what is wrong with my Maytag refrigerator
You have a bad high voltage board call the manufacturer, if the unit is under 2 yrs old they may help cover the repair with the problem your having.
SOURCE: I need the wiring diagram for an ice maker for the
Bring your model number to my site and enter the model number in Model search. The search will take you to your model and on left side of screen scroll down to wiring diagrams. Click it and you will get the complete wiring diagram. At top right you will see the ice maker. Hope this helps, Thanks, Sea Breeze
Click below
http://servicepartstec.blogspot.com/
SOURCE: Maytag refrigerator ice maker, pouring water out where ice should
change ice maker or check defrost
SOURCE: I have a Maytag MTB2156DE refrigerator with an ice
the water line comes from the bottom back of the fridge it sound like you have a blocked line meaning
you have a bad water replace valve and clean out line
SOURCE: Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Testimonial: "Thank you. We will work on that and see what happens. "
Here
is a tip that I wrote about the reasons why ice makers do not
work.
Ice
Maker Problems
and Ice Maker Troubleshooting
heatman101
