Craftsman 675 Torque 190cc 21" Briggs  Stratton RearBag Push Lawn Mower (CA) () Logo
A
Anonymous Posted on Jun 07, 2014
Craftsman excessive vibration lawn mowers problems
J.D. Browning
Level 3:
  • Craftsman Master 2,760 Answers
  • Posted on Jul 09, 2015
J.D. Browning
Craftsman Master
Level 3:
Answers
2760
Questions
0
Helped
1015027
Points
6696
Vibration in a walk behind mower is most always a imbalance in the blade , there lots of things that cause this , from loose blade , to bent blades
remove blade and test with blade balance , there not expensive ive seen them with a sharping stone for less than ten dollars before
pull spark plug before you remove blade 4 safety
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on May 31, 2009
SOURCE: Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
Anonymous
  • 65 Answers
  • Posted on Aug 22, 2009
SOURCE: Looking for a manual on a Craftsman Eager-1 .
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=131.90300&productCategoryId=1503700&brandId=0247&modelName=ROTARY-LAWN-MOWER&diagramPageId=00001&documentId=00035640&pop=flush
PARTS LIST AND PICTURE.. WHAT DO YOU NEED TO KNOW OR DO??
Anonymous
  • 16 Answers
  • Posted on Aug 31, 2009
SOURCE: craftsman eager-1 lawnmower will not start
Hi, The first thing I always check for is fresh fuel (less than a couple of months old) old unleaded may well be fine in your car but low compression engines fitted to garden equipment need fresh fuel. next thing to check is that the choke flap is closing fully, dont rely on the position of the control lever, remove the airfilter cover and see that the flap is fully closed, if it's cracked open just a little bit it will stop engine starting ( unless the filter is really dirty) another thing to check is that the blade is tightly secured, on direct drive mowers the blade acts as a flywheel. did you hit an obstruction the last time you used it, if you did you may have sheared the flywheel key(poor spark on points ignition or good spark but timing out of sync on electronic ignition. hope this helps, regards Tony (England UK)
itsman
  • 89 Answers
  • Posted on Nov 04, 2009
SOURCE: craftsman lawn mower wheels won't turn
take cover off the top off deck and see if your belt have came off next turn deck sideways but before you turn it sideways take air filter off cause oil can come through and ruin the filter noe look and make sure the belt is on the pully
Anonymous
  • 169 Answers
  • Posted on Nov 21, 2009
SOURCE: How to change the v-belt on a craftsman walkbehind
Remove the belt cover, Remove the blade and blade adaptor. Remove belt guard and slip off old belt. Install new belt just like it was removed. Install parts and you should be good to go. Hope this helps
Excessive vibrating
Exsessive vibration is normally attributable to the mower deck. If the vibration is occurring while the blades are engaged and cutting this would indicate a need for further investigation. Check the blades for damage or uneven ware. If the blades are new or appear in good shape check the mandrals and shafts to ensure they are not Brocken or bent. You can get mandrel assembly's for around $60.00 online and replace all you need in one go.
Craftsman excessive vibration problems 625 series
probably a bent crank shaft or blade is out of balance
Excessive vibration > lawn mowers
bent crank shaft or blade out of balance
My 2003 FORD TAURUS IS VIBRATING WHEN I ACCELERATE MORE THAN 60 MPH. IVE REPLACED MY TIRES WITH NEW ONES AND THEY WERE ALSO BALANCED. ONCE I TAKE MY FOOT OFF THE ACCELERATION THE VIBRATION STOPS.
The trans axle in the transmission has too much play from wear. It works like a rear end in a rear wheel drive.Excessive wear there will give you that kind of vibration.It could be wore out.
My craftsman riding mower vibrates so bad when I engage the mower. How do I stop vibration?
Things you need to check, loose blades, blades out off balance, bad belt or loose belt, bearings in the blade mandrels worn.
3helpful
2answers
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Problem:gasoline mixes with engine oil on 6hp. Craftsman lawn mower.
Hard starting? excessive choking caused by excessive cranking, try a tuneup, beware of Gas in the
oil, it will thin the oil out and result in the engine throwing a rod or seizing
Jul 05, 2011 • Garden
1helpful
2answers
19.5hp 42" cut. Shakes when mower is engaged to cut
how hard does it shake? and does it mow?
most lawn tractor will shake a quick almost violent shake at first then it should vibrate quite a bit more while you are mowing this is just caused by the power being pulled from the motor to power not only the drive but the mowing deck. its normal.
if its worse than what i described you may have a bigger problem, if there is excessive clanking from the deck your blade may be loose/installed upside down.
Started to vibrate and stopped working when I passed over roots.
you had the mower up on it's front oil leaked in the head take the plug out and pull it a few times to clear the oil out and clean the plug it should take of the problem
Lawn mower has a loud noise like something is hitting on metal part.changed blade this year with no problems. loud excessive vibration when running.
Sounds like your deck may be bent in and the blade is hitting. Remove the sparkplug and tilt the mower back on the handle (I'm assuming this is a push mower) and have someone pull the rope while you watch the blade underneath. You should see the problem.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
