Question about Proscan 8" Tablet with 4GB Memory
I can't get the apps to work - Proscan 8" Tablet with 4GB Memory
    Scholar:
    New Friend:
  • 183 Answers
Uninstall and reinstall the apps. otherwise you should contact the manufacturer of your device for tech support.
Posted on Jun 07, 2014
6ya staff
SOURCE:
How do I unfreeze a Google app page?
Reset the App
1. Double-click the Home button. This minimizes the app and displays the iPad's multitasking screen.
2. Drag the stuck app upwards on the screen. This forces the app to close and removes it from the iPad's memory.
3. Press the Home button to display the iPad's home screen. Tap the app's icon to relaunch it. Any unsaved data, like words you typed in a document or progress in a game, is lost, but the app opens and should respond normally.
Apr 21, 2015 | Apple iPad Tablets & eReaders
123 Greeting Cards cutting in and out on my iPad. App
Hi Emma
Double click the round main button.
This leaves a list of all running Apps.
Slide all the Apps upward to drop out of memory.
When All Apps are quit, hold the top button down for 5-10 seconds to cause the iPad to Shut Down. Wait 5 Seconds then press top button for 5 seconds to restart iPad.
Try your 123 Greeting Card App again. If not fixed, quit the App and hold down on the App till it wiggles with an x in corner.
Click the x to delete the App. Go to App Store and re download App for free.
The above procedure fixes most problems.
If that doesn't work you may need to re install the IOS completely.
If so Hold the Top Button & Round Button down together for about one minute. You will be prompted to connect to iTunes on your computer to do a restore.
Hope this helps...
Mar 01, 2015 | Office Equipment & Supplies
My rosary app sound stopped working
It seems there is a bug int he app. Try contacting the person or company that made the app. You'll find the information when you look up the app info on iTunes on your PC or Mac.
Once the bug is patched, they'll release an app update in the app store.
Some old app's don't get updates anymore and disappear from the app store. Try finding another rosary app.
Keep praying!
Feb 26, 2015 | Apple Ipad I-pad
Why wont my hannspree 10.1" tablet connect to onboard cameras?
to contact a camera, you need a correct working camera app. If the app you try to use does not work, reinstall the app, or choose another app from the App Store.
Jul 22, 2014 | Hannspree HannsPad SN10T1
On my Huawei MyTouch Q phone the com dot huawei dot mytouchlauncher app keeps stopping unexpectedly whenever installing new apps
Resolution Steps App previously worked
If the app that is showing errors has previously worked and not been updated, follow these steps:
  1. Think about the pattern of what you were doing when the device froze, and what programs were open in the background. Use the answers to focus on device functions or apps that are not working correctly.
    Note: If the problem is related to more than one specific app, see: Device is slow / freezes / restarts / or displays memory errors: Android
  2. Check the docs for your device to see if there are any specific instructions for it
  3. If the problem is related to contacts or an 'android.process.acore', back up your contacts:
    1. From the Home screen, press the Menu key.
    2. Touch Settings.
    3. Touch Accounts & sync.
    4. Turn off all synchronization to Google accounts and T-Mobile Contacts Backup.
    5. Return to the Home screen.
    6. Open the App menu.
    7. Touch Contacts or People.
    8. If there are any contacts listed, they are stored on your phone (because you turned off the ones synced). From the menu, export them to the SD card to save them.
  4. Clear the app cache and data:
    2. Touch Settings.
    3. Touch Applications.
    4. Touch Manage Applications.
    5. Touch All.
    6. Select the application that is having issues.
      Note: For the following errors:
      • android.process.acore: Select Contacts storage.
      • android.process.mms: Select Messages.
      • com.google.process.gapps: Select Download Manager or Downloads (At the bottom of the list). Make sure the Downloads Manager is enabled. If it isn't, enable it before proceeding.
      • TWlauncher process com.sec.android.app: Select TWLauncher.
    7. Touch Clear data and Clear cache if they are available. This resets the app as if it was new, and may delete personal data stored in the app.
  5. If you turned off sync, return to Accounts & sync and turn it back on. If necessary, import any contacts you exported to the SD card.
  6. Uninstall all third-party party task managers, battery saver, or apps that close programs. For information, see Manage Applications: Manage memory on Android.
  7. Restart the device.
  8. Open the app to test if the problem happens again.
  9. If the problem recurs, uninstall the app (if possible).
  10. Wipe the cache partition to clear system memory.
    Note: To find steps for your device, search Support Community for: wipe cache [device name]
  11. Open Play Store, and re-install or update the app.
  12. Open the app to test if the problem happens again.
  13. If the problem recurs:
App never worked OR app received update and stopped working
If the app that is showing errors never worked OR was updated and then stopped working, then follow these steps:
  • If the error is with a pre-installed app, then look for more content in your device space or user manual.
  • If the error is with third-party apps, then contact the app developer. T-Mobile does not support third-party apps.
Mar 19, 2014 | Cell Phones
Windows 8 apps NOT opening
Try creating another admin account
This person had similar problem and that worked
Solved Windows 8 apps wont load
Feb 09, 2018 | Computers & Internet
WhoCalled iphone app no longer works and is unavailable from iTunes, help!
it's very possible that apple has decided it's no longer allowed in the iTunes app store.
They maintain control of all the apps that are published in the app store and have the right to remove any they see fit to.
It's very possible that the older version of the "WhoCalled" app will not work with the latest iOS. Also what happens sometimes is they will change the name of the application and re-publish it. There are a number of things that could have happened....I would look to see if they have made updates to the app that could have changed the name or if the company that made it was purchased and a new iteration of the app is available. If not I'm sure there are plenty of apps in the app store that do this.
May 16, 2012 | iPhone Apps
Itouch app not workin
hey did u try a cracked app or what??
if u r tryin those third party apps those maybe no cracked well.. so try downloadin from appulo.us
Apr 19, 2009 | Apple iPod touch
Proscan 8" Tablet with 4GB Memory Logo
57 people viewed this question
Top Proscan Computers & Internet Experts
 Mikey
Mikey
ray gallant
Are you a Proscan Computer and Internet Expert? Answer questions, earn points and help others
