It is fully charged ,but wont run
SOURCE: I have purchased new batteries for my mobility
The control seems to be the issue. I have rewired so many scooters. When you have power and it wont go, it is usually the control. If you cannot afford the part right away, you can rewire it or have it rewired direct
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
SOURCE: Scooter stops intermittenly
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
SOURCE: Strider mobility scooter shows fully charged but
may sound silly, but have you checked that it's not in freewheel mode, as this would prevent the motor engaging
