Cell Phones Logo
Robert Morgan Posted on Jun 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drivers for humlin headphones - 3110 Nokia Cell Phones
Peter Dragonetti
Level 3:
  • Master 798 Answers
  • Posted on Jun 06, 2014
Peter Dragonetti
Master
Level 3:
Answers
798
Questions
Helped
209377
Points
2183
Hi Robert Morgan as far I can see the headset is Wireless so you need to CONNECT the headset to the phone via wifi or bluetooth. hope it helps....
2answers
My headset is not working
Most Dell computers have special hardware and software that are set up to automatically adjust the configuration of the headphone ports when headphones are connected, muting the primary speakers in the process. If no sound is coming out of your headphones, this is most likely caused by a configuration issue that can be resolved with a few simple steps.
Basic Headphone Troubleshooting
If no sound is coming from your headphones, confirm that the headphones work properly by using them with a different device. After this, confirm that the headphones are plugged into the proper jack. If your CD/DVD drive has a headphone jack in front, audio will only be played through this jack when you are playing a disc. On a desktop computer, the correct jack to use for headphones is usually color-coded green, while notebook computers will have headphone icons next to the correct jacks. Finally, check the speaker icon in the system tray to make sure that your sound output is not muted. b> Troubleshooting Notebooks b> Most Dell notebooks use a special type of audio jack. The jack, along with the sound drivers that are installed, automatically detect whether headphones or speakers are plugged in and adjust the sound output accordingly. If this does not happen when headphones are plugged in, the sound drivers may be at fault. Visit the Dell support website and download the most recent sound drivers for your notebook. If this does not help, some users have reported success with removing the sound drivers completely and letting Windows install generic drivers automatically. Last Resort b> If all other options have been exhausted, the last resort in troubleshooting a headphone jack is running a complete system recovery operation. This will completely erase all of the information on your primary hard drive partition and reinstall Windows along with the drivers for all of your hardware. This is an extreme measure, as you will lose all of the information that you have stored on the hard drive. However, it will resolve the issue if it is caused by a software problem. If the issue remains, the headphone jack must be replaced. Hope this helps.
b>
Dell laptop headphone sound on out headphone no sound
Sound Loss in Dell Computer Headphones b> Most Dell computers have special hardware and software that are set up to automatically adjust the configuration of the headphone ports when headphones are connected, muting the primary speakers in the process. If no sound is coming out of your headphones, this is most likely caused by a configuration issue that can be resolved with a few simple steps.
b>
1helpful
Jbl 610 driver
Windows Vista should see the bluetooth headphones without any extra drivers. If you open your bluetooth options, and you can see the headphones, and it asks for a password, try 0000 or 1111.
Also - check your computer to ensure that it does have bluetooth capability. If the computer doesn't have bluetooth built in, you'll need to use the USB communicator that should have come with the headphones. If you don't have the USB stick that came with the headphones, your best bet is to contact JBL and see if they will send you a new one.
Another thing you can try, just to verify the headphones are good - is to try to sync them with an ipod or iphone and see if you can listen to music through them.
2helpful
I have a Latitude D600 laptop. When I plug in my headphones, the sound still plays through the built in speakers. When I twist the plug in the jack I can sometimes get sound in the headphones but it still...
I dont think the JACK is the problem, I suspect a bad headphone wire (intermittent) or an incorrect driver, headphone jacks in laptops are software controlled, (no mechanical switch inside) if you hear sound in both the headphones and the speakes it is a driver issue, try updating the driver, if the headphone wire is erratic it can fool the software that controlls the input and do crazy things also...
2answers
Why does the audio cut out on acer z5700 speakers when you connect to a source at the audio output in the back.(expect this only when you connect headphones to headphone input)
When you connect headphones to your computer the computer will only send sound through the headphones and not allow sound to come out of the speakers. this is the way almost all audio drivers are setup, it detects the speakers and the headphones as 2 different devices and will only play sound through one (headphones first and if there are no headphones then speakers).
The only way I know to resolve this (and I hate this suggestion) is to purchase a headphone splitter. Connect the speakers and the headphones through the splitter, the quality of the splitter will determine the quality of the sound.
You could try going to the audio driver options (if there is any program installed by the audio driver) to see if you can get it to play through both but with both my Acer laptops I have been unsuccessful.
Hope this helps.
2answers
Headphone audio doesn't work when pluged into headphone jack but will work if pluged into speaker jack
since speaker works nothing should stop the headphone it is likely that the headphone is faulty.try another headphone
The headphone output on my PC does not work. There is also no settings for headphones in the Realtek driver (for example to mute the PC speakers but engage the headphones). I have checked and supposedly...
go to the device manager and search for audio drivers and check if the drivers are installed if not use the DRIVERS AND UTILITY cd to re-install the audio drivers.
2helpful
My Logitech headphones mic won´t work with windows xp. Can hear, don´t hear me.
Your headphone mic is all right. The problem is with the sound driver you are using. Many a time the headphone jack are not properly connected so it may be another issue for not working of your headphone. Your operating system is all right check out the sound driver setting from the control panel.
Good Luck
Dell inspiron 1520
Try uninstalling the software, then re-install it again and only plug the headphones in when asked to do so, this will enable the program to pick the headphones up and install the correct driver, if windows picks it up as new hardware and tries to install the drivers for it then it will not work correctly.
What version of vista are you using 32 or 64?
Do I need Vista drivers to get my headphones and mic to work?
Wired headphones and microphone do not need any driver to work on Vista.
Wireless headphones and mic need drivers.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
