My Horizon Series Beverage Air freezer is flashing code da.
SOURCE: Can an upright freezer be used as a beer fridge?
if it freeze's water it won't do,test first!
SOURCE: Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
SOURCE: KF48 Beverage Air Freezer permently stuck on "defrost."
Unplug the fridge overnight and defrost it completely. Ensure the thermostat is properly set.
If it does not restart normal function after you plug back, then there may be a fault concerning the digital control, in that case call the number listed on the owner manual.
SOURCE: Beverage-Air KF48-1AS not coooling, fans not running
some thing wrong with the evaporator fan motor. make sure the motor turns freely. your going to need service .
SOURCE: beverage air model sur27 refrigerator r134a powers
The larger pipe on compressor should get cold. The smaller should get warm to very hot depending on ambient conditions. Parts should be available, including a universal relay kit I could hook you up with. First determine if the compressor is running. Let me know. :)
