Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. Check for air leaks on or around any intake pipework using a good spraying of carb cleaner, if the engine surges then that's the leak. Check wiring to Maf and if the inside is dirty, again use carb cleaner liberally...NOTE: do not use Wd40... If the code comes back, it may be necessary to replaced the mass air flow sensor.
